分页: 1 / 1
[NEW] AmazFit-X Editor for Windows
发表于 : 04 2月 2021, 10:34
Inquisitom
AmazfitX Watchface Editor based on SashaCX75 "Amazfit Watchface Editor" (initial post HERE)
Based on his shared sources for v9 beta including the AmazfitX, I propose this new dedicated version on Windows for this watch only.
Scope:
- AmazfitX only
- limited support - I'll mainly concentrate on new JSON capabilities if alternate extract/unpack tools permits it
Out of scope:
- other watches - as I only have an AmazfitX, and there are good alternate apps for them
- translation will mainly focus on english
- regular updates, based on SashaCX75's app (except if drastic incredible needed important changes !)
Screenshots:
Changelog:
[version 9.3.3.0]
- Added the "UV Index" feature under the Weather tab for Amazfit X
[version 9.3.2.1]
- corrected Calories segments not displaying on watch (thanks @SandraMichael for reporting the bug)
- added some missing english translations (other languages have not been updated)
- based on @SandraMichael feedback: removed warnings for different images used in hour and minutes tens and ones
[version 9.3.1.3]
- removed Calories ProgressBar (non circular) : simply does not work on watch
- little bug fix with PAI Circle option activated
- removed conversion tab, as the tool is used only for AmazfitX (pls use SashaCX75 official tool for this)
[version 9.3.1.2]
- changed preview order to have seconds on top, then hours and minutes
- correction of preview for Calories Progress Bar
[version v9.3.1.1]
- correction of PAI preview circle
- correction of Steps Circle Progress coordinates calculation
- correction of preview generator (linked to activity mainly)
- program can now check for new versions at startup (can be disabled in options)
- some little cosmetic changes
v9.3
- JSON handles new parameters:
* Calories: ProgressBar (non circular), Segments
* Stand: ProgressBar (non circular), Segments
* PAI: ProgressBar (non circular), Segments
- integrated "py amazfit tools" (main.exe) has been heavily modified to support most changes and more (source here: https://github.com/Inquisitom/py_amazfit_tools/)
- StepsProgress section has been transferred in Activity/Steps for better usage
v9.2
* PAI Progress (circle)
* Sunset Time
* Sunrise Time
- Preview values now integrates PAI, Stand & Sunset, Sunrise
- Generated GIF supports those new additions
- improved all text alignment coordinates
- can automatically insert preview image in BIN (you need to have it configured in the dial)
- can automatically generate animated gif at each BIN generation
- automatically open and displays the LOG file after BIN generation
- new fixed preview picture at the right of the window
- list of assets (images) are now shown simultaneously with white and black background
- JSON handles new parameters: PAI and Stand activity
- added some various explanations (day & night temperature versus current, goal achievement)
- changed pictures to reflect AmazfitX
- changed icons to reflect AmazfitX
- changed the Window and Executable name to avoid confusion
- removed all other Amazfit watches (there is the original tool for that!)
- written new options by default in english - multilanguage is not yet supported
- other "little" stuff
Clik here to Download the latest version
SashaCX75 for his great tool, and sharing the sources
Lordalpine for extracting stock AmazfitX dials, which helped me add the PAI & Stand
Re: AmazFitX Editor for Windows
发表于 : 04 2月 2021, 15:28
Displaying a list of images simultaneously on a black and white background is probably a good idea.
If I remember correctly, for Amazfit X, the preliminary calculation of the file size does not work correctly, because there is a different algorithm for packing the background image.
Re: [NEW] AmazFit-X Editor for Windows
发表于 : 10 2月 2021, 10:14
Inquisitom
New Version released - the download link on the 1st post has been updated.
Changes:
* Sunset Time
* Sunrise Time
Supporting Demo Dial here:
https://amazfitwatchfaces.com/amazfit-x/view/105
发表于 : 15 2月 2021, 20:07
Inquisitom
New Version released 9.3 - the download link on the 1st post has been updated.
Changes:
Now supports stock dials here and their features:
- https://amazfitwatchfaces.com/amazfit-x/view/111
- https://amazfitwatchfaces.com/amazfit-x/view/110
If you encounter any bug or strange application behavior pls raise :idea:
发表于 : 16 2月 2021, 12:27
zyfish
thanks。。。
发表于 : 16 2月 2021, 19:09
Inquisitom
New Version released 9.3.1.1 (download link in first post)
发表于 : 28 2月 2021, 12:27
pa5t1s
Hehe ! Looks great !! Thanks for sharing 👍
发表于 : 02 3月 2021, 10:10
Inquisitom
Here are the latest tool changes:
[version 9.3.2.1]
[version 9.3.1.3]
[version 9.3.1.2]
发表于 : 04 3月 2021, 11:21
mickdu59
Hello, still nothing for the GTS 2?
发表于 : 04 3月 2021, 15:58
Inquisitom
Hey Mick,
Seems you're looking at the wrong thread - this one's for AmazfitX only.
发表于 : 07 9月 2021, 14:14
Inquisitom
FYI - to all Amazfit X face makers out there...
I have been able to add the UV Index for the Amazfit X with lot of reverse engineering !
A new release of the tool will soon follow.
Hoping that I will be able to add wind and humidity in a near future :)
发表于 : 13 9月 2021, 07:30
Inquisitom
[version 9.3.3.0]
Hoping you'll like it :)
发表于 : 02 11月 2021, 04:03
Aaronfet
if you already own Pro Tools and use it with a 3rd party interface: there will be no way to switch to an M-Box Pro without buying the software twice, correct?
Just looking for clarification on this.
发表于 : 07 12月 2021, 05:27
amazneo
Great job! Will this work on the GTS model? Do we just change the display dimensions to match the GTS?
