Pagina 1 di 1
GTR 2e Watchfaces
Inviato: 30 gen 2021, 08:08
da ruxxzif
watchfaces for GTR 2e not same as GTR 2?
Re: GTR 2e Watchfaces
Inviato: 30 gen 2021, 08:30
da eliasf
I've tried many for GTR2 on my e and haven't had a problem yet, they all worked!
Inviato: 02 feb 2021, 07:47
da ruxxzif
okay thanks! gonna try it
Inviato: 02 feb 2021, 07:48
da ruxxzif
eliasf ha scritto: 30 gen 2021, 08:30
by using Aw apps?
Inviato: 02 feb 2021, 07:58
da ruxxzif
Aw apps keep tellling m to sync with the zepp!
ive already sync it , still no sucess to change WF
Inviato: 02 feb 2021, 09:02
da eliasf
ruxxzif ha scritto: 02 feb 2021, 07:58
No the AW app doesn't work for me either.
Notify for Amazfit from playstore.
If you go into the far right tab there is a section Watchfaces and there you choose Amazfitwatchfaces.com and get all the options from AW, it's like a web UI inside the Notify app.
From there everything works.
Let me know if you succeed, otherwise I'll post some screenshots for you!
Inviato: 14 feb 2021, 17:09
da AlterSchwede62
What? Where exactly should that be?
I have the GTR2 e and I do not see anything anywhere...
In the Watchfaces section of Zepp there isnt any Amazfitwatchfaces.com
What Notify App do you mean?
Can you add pictures?
Thanx.
Inviato: 15 feb 2021, 08:03
da AlterSchwede62
Ah, I did not read the most important:
"Notify for Amazfit"
This is a very nice, little and very informing App, that allows uploading Watchfaces from here (Amazfitwatchfaces.com). :-D
Inviato: 15 feb 2021, 08:12
da eliasf
AlterSchwede62 ha scritto: 14 feb 2021, 17:09
Thanx.
This is the app:
After you pair the app with your watch you need to go here:
Then you choose Watchfaces:
And then Amazfitwatchfaces.com:
Then you choose GTR2-GTR2e and install what you like!
Inviato: 21 mar 2021, 17:11
da Fulvio_61
I just ordered a GTR2, which I will use with IOS. Not having found "Notify for Amazfit" on Apple Store, I have to think that I will not be able to install Amazfitwatchfaces.com faces?
Inviato: 28 mar 2021, 09:36
da mrlawrencelam
I have no problem installing GTR2 watch faces AmazFaces on my GTR-2e through syncing via AmazTools. If you are getting "Generic Error" repeatedly after many attempts, try to delete some existing faces in your watch.
