Pagina 1 di 1
New Feature for Next Update Firmware
Inviato: 06 apr 2018, 02:25
da Kojarmax
Few days ago i has sent email to amazfit dev. I request for next update an ability to counter by touch. I think this feature very usefull for sport or other activity everyday.
Re: New Feature for Next Update Firmware
Inviato: 06 apr 2018, 08:11
da GIK-Team
Kojarmax ha scritto: 06 apr 2018, 02:25
Can you please explain your idea in details?
Inviato: 06 apr 2018, 08:18
da Lukass
In 6 hours there should be a new beta, we'll see what they add there
Inviato: 14 apr 2018, 22:22
da sharkyw1965
Could we have the time showing or the ability to see the time when recording sports activities?
Inviato: 17 apr 2018, 11:15
da Poipoi
Hello
Would you please Translate the Firmware into French?
Tank you
Inviato: 29 apr 2018, 10:10
da BaQs
I'm kind of new here, but if you are looking for people to translate firmware into french, do not hesitate, I'm used to it.
Just one question: does translating the firmware into french enable the ability to use accents ("é","è","à") ?
Inviato: 30 apr 2018, 18:29
da osmat
BaQs ha scritto: 29 apr 2018, 10:10
The administration does not translate the firmware. You can add the desired characters by changing the font file.
Inviato: 14 lug 2018, 17:09
da Kojarmax
GIK-Team ha scritto: 06 apr 2018, 08:11
There only two feature on timer. Countdown and Stopwatch. I m suggest to add feature like step counter. We can set how much to be count. So we count by touch on screen. And vibrate if count has finished
Inviato: 31 lug 2018, 18:58
da Alber
A 'steps countdown' would be cool but I'd prefer if an update allowed the option to delete/change/overwrite default watchfaces
Inviato: 01 ago 2018, 08:41
da osmat
Similar wishes you better write in technical support
