Page 1 of 1
AmazFit BIP S Lite: supported by AmazFaces app (iOS)?
Posted: 29 Sep 2020, 21:07
by Soul71
I've bought the
AmazFit Bip S Lite (yes, really Bip
S Lite) and tried to install a new watchface with the AmazFaces app, but it doesn't work.
My guess: the Bip S Lite isn't supportet by the AmazFaces app yet.
Is that the case? Or do you have any tipps?
Every time at a watchface screen I tap the "Install" Button,
after I downloaded it (I tried some BIP S watchfaces),
nothing happens other than the color of "Install"
changes from black to dark orange as long as I tap.
The Watch is connected to my iPhone,
i can sync over the Zepp app.
I tried all the tipps (About connect: BIP) in the App,
but nothing changes.
My Devices and Software-Versions:
iPhone 11, iOS
14.0.1
AmazFaces: Version
2.8
Zepp (formerly Amazfit): Version
5.2.0
Amazfit Bip S Lite: Firmware Version
2.11.50
I would be very happy for any help!
Greetings from Germany
Soul71 / Matthias
Re: AmazFit BIP S Lite: supported by AmazFaces app (iOS)?
Posted: 30 Sep 2020, 06:11
by Stas
Update coming soon with fixes
Posted: 23 Oct 2020, 14:10
by Soul71
Any news on when the update / next version of AmazFace is being released?
Posted: 23 Oct 2020, 14:47
by Stas
Amazfaces app detects Bip?
Soul71 wrote: 23 Oct 2020, 14:10
Posted: 23 Oct 2020, 14:56
by Soul71
The AmazFaces app says under settings
Connected device
* amazfit BIP
It seems so. But my watch is the AmazFit Bip S Lite ...
Mmmh.
Any Info on when the update goes online?
Posted: 23 Oct 2020, 14:58
by Stas
The update will be by the end of the month
Soul71 wrote: 23 Oct 2020, 14:56
Connected device
* amazfit BIP
Mmmh.
Posted: 07 Nov 2020, 14:09
by Soul71
Any News on when the update comes?
Posted: 07 Nov 2020, 15:43
by GIK-Team
Soul71 wrote: 07 Nov 2020, 14:09
Beta now available.
Posted: 07 Nov 2020, 22:02
by Soul71
Ok, now I installed the iOS-Beta and tried to install BIP S watchfaces to my BIP S Lite.
It doesn't work.
Should it work with the beta?
What can I do to help?
Posted: 08 Nov 2020, 08:56
by GIK-Team
Soul71 wrote: 07 Nov 2020, 22:02
It doesn't work.
We are still working on the problem.
Posted: 13 Nov 2020, 09:57
by Wallaby
Hello.
I`ve the same problem with the AmazFaces App. I downloaded the latest Beta-Version this morning and the cycle runs as follows:
I choose a watchface in the App and klick on the Download-Button. The next screen appears and I see that my Bip S Lite is connected (shows 84% battery status).
Then I click on "Install". After some seconds a screen shows up: "Synchronize the watch with the MiFit/Zepp application (open and check the MiFit/Zepp connection status)". Also there are 3 buttons: 1. Mi Fit, 2. Go to Zepp and 3. back. When I click on the "Go to Zepp"-Button the Zepp-App opens up but nothing else happens. Even if I go to the Watchface-Settings I can only see the Watchfaces built in the App itself. The chosen Watchface from the AmazFaces App doesn`t shop up.
Settings:
Bip S Lite (product was sold at ALDI supermarket in Germany)
iPhone X with iOS 14.2
Zepp App with Version 2.1.1.50 (Setting, that the watch is visible, is on "on")
Latest iOS-Beta AmazFace App from this moring
Language: English and Connected Device: amazfit BIP
Maybe these informations might help you to solve these problems.
Thanks.
