Página 1 de 2
Share your today's watchface / watchface making process [Mi Band]
Enviado: 29 Ago 2020, 08:10
por Testament
Hi , I am testament here ,
I am starting a challenge for you all , this challenge is allowed for both mi band 5 and mi band 4 users .
The challenge is that -
You have too share your daily watchfaces that you are using , you can also tell your favorite ones and can also discuss the badass ones . You can discuss about bugs here also .****NOTE - for only devices mi band 4 and 5 .
Thanks bye.
Everyone can also share their own originally created watchfaces here.
And can also add making a watchface .
Re: Share your today's watchface
Enviado: 29 Ago 2020, 09:32
por diopter
Enviado: 29 Ago 2020, 10:52
por urieleugenio
Right now I'm using this one (simplified, en ddmm version):
https://amazfitwatchfaces.com/mi-band-5/view/373
This other one was my go-to watch face until recently, and I made different versions with a more or less complex dial:
https://amazfitwatchfaces.com/mi-band-5/view/323
Enviado: 29 Ago 2020, 15:08
por Testament
You can also share how you make your own watchfaces in a detailed manner , other users can find this thread and it may help them
Enviado: 30 Ago 2020, 08:58
por Jackall Digital
I'm still using my WF Simplicity (Green) as it's easily visible even on the lowest brightness.
https://amazfitwatchfaces.com/mi-band-4/view/13569
For anyone that wants to know the ins and outs of making Mi Band 4 Watch Faces ( even tilted/angled ones), I have a playlist
https://www.youtube.com/playlist?list=P ... HST_ZN7moS
I would say most of what I say in the videos is still true for the Mi Band 5, but they did add some additional options and changed the syntax a little bit in some cases.
Enviado: 30 Ago 2020, 15:56
por Testament
Any method all of you use to make watchfaces ?
Please tell .
Enviado: 30 Ago 2020, 20:52
por urieleugenio
I use Photoshop. I make different layers for each element, so that I can move them around until I'm happy with the result.
Then I crop the canvas and hide layers to save the images for each individual elements (like numbers 0-9 and such). I work with images without background when possible, so I can keep editing the file later on.
Finally, I use the Photoshop file to find the X,Y position for the elements.
For the JSON file, I just revise the files for existing watch faces, to see how the elements are coded.
BTW, some people leave unknown elements on the JSON files (for the weather icon, for example). I found the watch face works well without the unknown elements.
Enviado: 31 Ago 2020, 08:55
por Testament
urieleugenio escreveu: 30 Ago 2020, 20:52
Any builder that you use to make watchfaces ?
Enviado: 31 Ago 2020, 09:39
por urieleugenio
Testament escreveu: 31 Ago 2020, 08:55
lvpokka's Mi Band 4 WF Tool (v1.4.2) and Mi Band 5 WF Tool (v2.1.5).
I saw he just released a v2.1.6 version but I didn't try it yet. I downloaded the ZIP file but Windows defender considered it malicious and removed it.
Enviado: 31 Ago 2020, 09:58
por francesseSA
urieleugenio escreveu: 31 Ago 2020, 09:39
Can we use lumenvindex s watchface builder ?
Enviado: 31 Ago 2020, 10:21
por urieleugenio
Sure you can, but I never tried it. He's got only an MB4 version, and won't be making an MB5 version for now.
Enviado: 31 Ago 2020, 14:54
por Testament
urieleugenio escreveu: 31 Ago 2020, 10:21
How to use Photoshop ?
Enviado: 31 Ago 2020, 15:27
por urieleugenio
I don't know where to start to explain, better look for tutorial videos online.
You can create or edit images, make text and so on.
Enviado: 01 Set 2020, 02:54
por francesseSA
Can we use other tools then using Photoshop or other similar programs ?
Enviado: 01 Set 2020, 06:07
por urieleugenio
Sure. I know some people use Illustrator, or even paint. But I prefer to use Photoshop.
Enviado: 01 Set 2020, 06:47
por francesseSA
urieleugenio escreveu: 01 Set 2020, 06:07
Do you use the paid version ?
Enviado: 01 Set 2020, 09:58
por Testament
What your today's watchface guys ?
Enviado: 01 Set 2020, 11:59
por urieleugenio
francesseSA escreveu: 01 Set 2020, 06:47
Do you use the paid version?
Yup.
Enviado: 01 Set 2020, 13:39
por francesseSA
urieleugenio escreveu: 01 Set 2020, 11:59
Yup.
Any other program , please ?
por francesseSA
Yup.
How to use the paid version ? I have purchased it , and can you please tell me how to use it , as I am new using it .
Enviado: 01 Set 2020, 14:55
por urieleugenio
Start by unpacking an existing watch face, so you can see the elements and explore the code on the JSON file.
Then create your own design, or edit the one you downloaded by changing the background image or image elements, like time numbers and weather icons.
Finally, check the X,Y position for the elements on the JSON file to adjust them to your design, and pack the watch face.
Enviado: 01 Set 2020, 15:02
por francesseSA
urieleugenio escreveu: 01 Set 2020, 14:55
Thanks , so I can do try this method in photoshop , am I right ?
Enviado: 01 Set 2020, 15:08
por urieleugenio
I'll answer you by DM.
Enviado: 01 Set 2020, 15:22
por francesseSA
Enviado: 02 Set 2020, 06:12
por Testament
How to change the .bin size or rearrange it ?
