Page 1 of 1
Android TEST: AmazFaces app for Xiaomi Mi Band 5 (Mi Smart Band 5)
Posted: 10 Aug 2020, 08:50
by GIK-Team
We need AmazFaces app testers for Xiaomi Mi Band 5 (Mi Smart Band 5)
You need to test the functionality of the application for the Mi Band 5 smart bracelets and, in case of problems, report in this thread.
AmazFaces BETA for android
Re: Android TEST: AmazFaces app for Xiaomi Mi Band 5 (Mi Smart Band 5)
Posted: 10 Aug 2020, 11:50
by Cavoli
It's working
Posted: 10 Aug 2020, 13:04
by dragonn2
1. If you enter wrong passwotd on login, nothing happens. Add some feedback/error message.
2. When I logged in, it shows device "gts" and NO option to change it to Mi band 5. Not sure why it cannot find my device. I havent turned on any restrictions. It is already paired with my phone / Mi fit app.
Posted: 10 Aug 2020, 13:41
by diopter
If I try to download a WF, AmazFaces show me:
"Synchronize the watch with the MI Fit! app...."
Of course my MI Band 5 is synchronized with the MI Fit! app.
When I then touch "Retry Install", an error message is shown for a short time:
"Somethig wrong: e.m.a.r0.n: Location permission missing (code 3)"
For what AmazFaces needs the location?
I wll not give AmazFaces this perission, but for testing, I give it.
AmazFaces shows "scanning for devices..."
I touch "Retry Install"
I could not install a WF with AmazFaces .
MI Fit! is working all the time.
I got a firmware update to V1.0.1.32 just before trying AmazFaces .
Posted: 10 Aug 2020, 16:02
by Stas
Scanning denied when not allow permissions ACCESS_COARSE_LOCATION
https://developer.android.com/guide/top ... /bluetooth
"Of course my MI Band 5 is synchronized with the MI Fit! app."
This means that you need to synchronize data with Mi Fit, since the connection may hang.
diopter wrote: 10 Aug 2020, 13:41
Posted: 10 Aug 2020, 22:22
by diopter
"This means that you need to synchronize data with Mi Fit, since the connection may hang."
The connection was NOT hanging.
Posted: 11 Aug 2020, 07:44
by Stas
Which Android version do you have?
diopter wrote: 10 Aug 2020, 22:22
Posted: 11 Aug 2020, 10:44
by diopter
MIUI 11.0.9.0 with Android 9 PKQ1.190616.001
Posted: 11 Aug 2020, 13:57
by Stas
Didn't you provide access to geolocation for app ?
diopter wrote: 11 Aug 2020, 10:44
Posted: 11 Aug 2020, 14:40
by diopter
For testing, I give AmazFaces the permissions ACCESS_COARSE_LOCATION
I'm not the bug.
Posted: 11 Aug 2020, 16:09
by Stas
Can you record the installation process from your phone to understand the problem?
diopter wrote: 11 Aug 2020, 14:40
I'm not the bug.
Posted: 12 Aug 2020, 16:08
by Lienarhba
The app is although enough fine to be used but there are some errors -
1. This beta version of this app always says "synchronise the band with Mi fit app " if it's already synced .
2. The biggest problem is this whenever I add any watchface/ dial as my favorite it shows an error that this user ID has no favourites.
Till now I have not found any more problems . I will reply back if I find any more .
And please don't forget to fix them in the stable version of the amazfaces app .
Thanks.
Posted: 13 Aug 2020, 09:35
by Stas
Is the dial installed on the miband 5 ?
Posted: 13 Aug 2020, 10:40
by Lienarhba
Stas wrote: 13 Aug 2020, 09:35
Yes , it was installed on Mi band 5.
You are correct.
Posted: 15 Nov 2020, 22:11
by Nisei
I don't get why everything's so complicated...
Why not just let the app download the faces to the correct location on the band (without having to replace a previous installed face) so it appears in the Local band displays page in Mi Fit?
That's how the Mi Band 5 Watchfaces app works and it's great.
No fooling around with bluetooth connections and syncing or anything.
Posted: 17 Nov 2020, 11:09
by Stas
Thank you for replay, next update will be added work with local wf
Nisei wrote: 15 Nov 2020, 22:11
