Pagina 1 di 1
GTR display stop turn on for sleeping...
Inviato: 06 ago 2020, 08:00
da Pino20
Good morning,
I have not been able to understand if it is possible to deactivate the display turno on during sleep time.
It is very annoying....
DND doesn't seem to do that function, maybe I'm wrong.
Can you help me?
Thank you
Re: GTR display stop turn on for sleeping...
Inviato: 08 ago 2020, 08:40
da joebar78
You can do that with your amazfit app.
Select profil (in the bottom right) then your device and then Lift wrist to view info. Here you can turn off the display during your sleep time.
