分页: 1 / 1
Watchface for BIP S
发表于 : 26 6月 2020, 15:57
由 Chesco
Hi.
For a long time I have been using this Watchface for my Amazfit BIP; it's great.
Recently, I have bought a BIP S, but I cannot install the Watchface; steps and distance do not appear.
Could someone be so kind as to transform the Watchface BIP to BIP S?
Thank you so much.
https://amazfitwatchfaces.com/bip/view/21471
Re: Watchface for BIP S
发表于 : 26 6月 2020, 23:44
由 TXK
发表于 : 27 6月 2020, 14:39
由 Pdasnews
发表于 : 30 6月 2020, 03:11
由 afwafwafw
Hi, can you use 64 colors in custom watchface? I have not BIP S but curious.
发表于 : 02 7月 2020, 18:29
由 Pdasnews
发表于 : 03 7月 2020, 03:38
由 Joezer
Hi
I like the following face for the BIP S
https://amazfitwatchfaces.com/bip/view/36305 - made by [mention]p3d2[/mention]
However keen to get seconds on there and use black background
e.g. something like this (made a draft using Draw)
https://drive. google .com/file/d/1NwVOHOSI1sr4M6E6q8tnzInN4RMXeEMv/view?usp=sharing
Anyone who could make this?
I tried using the downloaded app on my computer but somehow it crashes as soon as I open a Json
Doesn't have to be exact as my example, but it gives an idea.
Or does something similar already exist?
发表于 : 03 7月 2020, 10:09
由 p3d2
Joezer 写了: 03 7月 2020, 03:38
Hi
https://amazfitwatchfaces.com/bip/view/36305 - made by @p3d2
You need to edit the json (for instance with notepadd++) and generate the bin with the Bip S Tool.
Tell me if you have any trouble.
发表于 : 03 7月 2020, 12:48
由 Joezer
thanks, I figured it out using the web based editor - which will work for BIP. Once I have something ready then I'll check what to do to convert to BIP S. Any idea which colour codes I should use - are supported?
发表于 : 03 7月 2020, 13:16
由 p3d2
Joezer 写了: 03 7月 2020, 12:48
I found somewhere the palette for photoshop(?) but since I only use GIMP I made a gpl (
bips_p.rar
- Bip S palette file for GIMP
- (242 Bytes) 已下载 183 次
) for it. If you use it, you can import the palette, then change the image mode to indexed and use the Bip S palette (you might need to work a bit with resize and dithering, different images will require different approaches).
Colour codes:
HTML: #AABBCC (where AA, BB, CC range from 00, 55, AA to FF)
RGB(0-255): AAA BBB CCC (where AAA, BBB, CCC range from 0, 85, 170 to 255)
发表于 : 06 7月 2020, 09:26
由 Upo
I use paint.net for simple edits. Homepage is getpaint.net
Attached Bip S 64 colors and Bip 8 colors palettes for paint.net.
Open app, beside the color wheel there is a palette menu (colored rectangle). Click open palettes folder and drop txt files from the zip to that folder. Close and reopen paint.net, there will be bip and bips palettes in the palette menu.
发表于 : 27 7月 2020, 08:10
由 SimsalaBip
Here is the link to the 64 color palette - in the ZIP file is also a picture only containing these 64 colors so you can extract the palette with every graphic program you want to use...
viewtopic.php?f=76&t=1419
