Сторінка 1 з 1
What's the situation with Seconds?
Додано: 12 червня 2020, 08:21
hakpoid
Hi all, I've recently purchased the mi band 4, just waiting for it to arrive now
I'm gathering a list of potential watch faces to install onto it when it does arrive.
Does anyone know what's the current situation with the seconds? Are they still broken?
I keep reading conflicting posts on the internet, with some people saying they are working, and others saying they don't work.
Do they still mess up all the other items on the watch face?
Also, if the digital seconds counter still messes up the display, does using an analogue second hand prevent this from occurring?
Is there a way that I can contact Xiaomi to get the seconds hand fixed? Or has other people here tried that to no avail?
Thanks for your help!
Hak
Re: What's the situation with Seconds?
Додано: 12 червня 2020, 14:36
Jackall Digital
As far as I know the digital second display messes with other properties (hides them after 1 seconds). I can't say if that's the same for analog since I never bothered making an analog WF with seconds.
When you have the mifit app installed you can leave feedback through the app, but I don't know if that is the right way to contact them. I doubt they'll fix the firmware especially now, since mi band 5 is close to release.
Додано: 13 червня 2020, 08:48
brunello
oltre ai secondi dovete usare lo shape dei secondi
"AnalogDialFace": {
"Seconds": {
"OnlyBorder": false,
"Color": "0x000000",
"Center": {
"X": 0,
"Y": 40
"Shape": [
"X": 0,
"Y": 2
"X": -1,
"Y": -2
Додано: 13 червня 2020, 14:21
hakpoid
brunello писав: 13 червня 2020, 08:48
"AnalogDialFace": {
"Seconds": {
"Center": {
"X": 0,
"Y": 40
"Shape": [
"X": 0,
"Y": 2
"X": -1,
"Y": -2
Hi, does this fix the problem with everything disappearing on the watch face?
Unfortunately I cannot try it now, because I am still waiting for my band to be delivered. I will definitely try it when it does arrive though.
Hak
Додано: 13 червня 2020, 17:57
brunello
si , devi inserire sia i secondi :
"Seconds": {
"Tens": {
"X": 43,
"Y": 44,
"ImageIndex": 121,
"ImagesCount": 6
"Ones": {
"X": 61,
"Y": 44,
"ImageIndex": 121,
"ImagesCount": 10
ed anche il analogdialface :
"AnalogDialFace": {
"Seconds": {
"OnlyBorder": true,
"Center": {
"X": 0,
"Y": 0
"Shape": [
"X": 0,
"Y": 0
"X": 0,
"Y": 0
"X": 0,
"Y": 0
vedrai comunque dei leggeri lampeggi allo scatto dei secondi che reinizializzano tutte le *.png
a me piace ugualmente , comunque aspetto la mi band 5 per vedere come saranno le sue funzioni
Додано: 14 червня 2020, 14:01
hakpoid
I see, that works for me! I'll try it out when my band arrives
Thanks a bunch!
Додано: 09 серпня 2020, 03:20
diopter
Just tested:
Seconds are NOT working on MI Band 5 with firmware V1.0.1.16
Додано: 10 серпня 2020, 14:26
diopter
Update to firmware V1.0.1.32:
