Pagina 1 di 1
Current Weather and Daily Weather
Inviato: 17 mag 2020, 10:54
da hnkaraca
Is it possible to display current weather and daily weather at the same time? or display one at a time?
What happens now with the watchfaces, if they show current weather, they display it some time after the synch with the amazfit app.
After some time (maybe a few hours I am not sure). It stops showing current weather and shows nothing. Just a symbol which is probably set for error symbol or "-" symbol.
According to the JSON, if I enable both current weather and daily weather, when it can not display the current weather I expect it to display the daily weather but it is not happening.
Instead of this it displays the error display after some time of the last sync.
Re: Current Weather and Daily Weather
Inviato: 18 mag 2020, 05:28
da hnkaraca
I think I found the answer why it is not updated automatically.
In Iphone if you restrict the Amazfit App to use the location services only when the app is running and if you set in the app to find the location automatically for weather forecast. It fails to update the weather on the watch (GTR).
Setting the location manually in the app solved the problem.
