Honor Band 5 Sourcefiles
Posted: 29 Mar 2020, 16:34
Hello Everyone,
I start this Forum to share Source files.
I developed and package_bandtool.bat file for Honor Band 5 watchface fast exporting.
Unzip the archive. Please change corespondent images in A00* folders with same resolution pictures. Be careful in naming the order of images shown depend on it. The A00* folder dependence is in watch_face_config.xml file.
Than run package_bandtool.bat
If *.hwt file size is suspiciously low and differs to much from original, It mean you made same errors in exchanging images or altering xml file.
Honor Band 5 watchface we be blank after upload. Change your watchfe simply pressing long on blank screen than swipe to change with built in Huawei watcheface. The same will happen if you upload hwt file with more than 600 kb com.huawei.watchface file inside it.
Thank You
Best wishes
Thank You
Best wishes
