Page 1 of 1
Amazfaces Failed to sync IOS
Posted: 16 Mar 2020, 14:12
by mahesoo
Hello currenty i'm on latest IOS 13 and using the latest amazfaces app on iphone. so i tried many times to change the watchfaces with amazfaces
the amazfaces app can detect my verge lite but always failed to sync can you give me a hand how solve that problem? thank you
Re: Amazfaces Failed to sync IOS
Posted: 17 Mar 2020, 16:54
by taw_bip
Posted: 19 Mar 2020, 20:31
by Giovana
Me too.
Posted: 20 Mar 2020, 14:44
by osmat
At what point does the error occur?
Sometimes the phone goes into sleep mode and installation may be interrupted.
Posted: 20 Mar 2020, 19:12
by Giovana
right at the beginning it already shows the error, less than 2 seconds. I have the impression that he loses the connection with the clock, having to locate it again.
Posted: 20 Mar 2020, 19:26
by osmat
Giovana wrote: 20 Mar 2020, 19:12
Specify the version of the application (at the bottom of the menu)
Posted: 21 Mar 2020, 11:20
by Oconrecon
Same here. iPhone X w latest software + a new T-Rex
I’ll keep my phone awake for the entire download, the watchface indicates it’s syncing, the app gets to 99%, then it says it failed.
I’ve tried:
• Restarting the app
• Restarting the phone
• Restarting the watch
• Cycling Bluetooth
Any ideas? Some great watch faces I’d like to try.
I’ve tried 5-6 times. Still no luck.
Posted: 21 Mar 2020, 11:47
by Oconrecon
taw_bip wrote: 17 Mar 2020, 16:54
Wha-what? Read those instructions. Maybe this just isn’t for me.
Are those instructions for the app?
https://amazfitwatchfaces.com/awapp
Or more the website?
https://amazfitwatchfaces.com/t-rex/updated
Posted: 22 Mar 2020, 18:56
by osmat
Oconrecon wrote: 21 Mar 2020, 11:20
I’ve tried:
• Cycling Bluetooth
Are you using a beta version of the application? Specify Version Number
Re: Amazfaces Failed to sync Android
Posted: 23 Mar 2020, 14:08
by Designman
I am having the same issue, running Amazfaces version. 1.4.66 on Android 10. The app worked well until the latest update, now it consistently displays a "not connected" message when I select download on any watchface. It often also shows a "Start Discovery" tab, which closes the app when I select it. I have switched Bluetooth off and on multiple times, restarted the watch and the phone multiple times, and have uninstalled and reinstalled both the Amazfit app and the Amazfaces app.
Posted: 23 Mar 2020, 16:37
by osmat
Designman wrote: 23 Mar 2020, 14:08
What is your watch?
Posted: 26 Mar 2020, 12:48
by Alcerri63
Hello, I have the same issue in my Android phone (asus max pro m2).
I just updated the Amazfit Watchfaces app, when asked by Google Play.
Thus, I don't think it's somehow related to the Operating System of the device: I guess that the problem is more on the new update.
Can you kindly help with this issue?
Posted: 26 Mar 2020, 12:49
by Alcerri63
Or, in case, is it possible to revert back to the previous version of the application?
Posted: 31 Mar 2020, 08:58
by Alcerri63
Hello all,
after the last update of the app, the synch process now is working perfectly fine on android!
Thanks to the deveolper!
Great job
