Page 1 of 1
Amazfaces old version
Posted: 15 Dec 2019, 14:29
by Gigs11
Na kojem linku možemo pronaći starije verzije amazface aplikacije za android. Ponekad se dešava da nakon ažuriranja aplikacija ne radi,dok je stara verzija ispravno radila.
Re: Amazfaces old version
Posted: 18 Dec 2019, 09:33
by Gigs11
Radije bi smo neku staru verziju,ako već nova i beta verzija ne rade
Posted: 21 Dec 2019, 17:48
by Gigs11
Novo ažuriranje,ništa ne radi,deinstalirati aplikaciju ili čekati,programeri ne znaju popraviti problem
Posted: 20 Jan 2020, 11:17
by osmat
Older versions may not work for their own reasons, so we recommend using the latest beta version. Unfortunately, due to frequent changes in the Amazfit and Mi fit applications, we do not always have time to respond in time to problems at work. Android update wave has made its corrections. We are working on fixing bugs and your feedback is important to us. So we returned to the application the old installation method through file spoofing.
Posted: 21 Jan 2020, 22:05
by Gigs11
Ne radi ništa,jednostavno ne znate popraviti...
Vidim da mnogima ne radi aplikacija nakon ažuriranja.
Jedno popravite,drugo pokvarite
Posted: 22 Jan 2020, 09:10
by osmat
We are sorry that you encountered a problem in the application. Older versions of the AmazFace application will not work correctly.
Posted: 31 Jan 2020, 01:56
by ShadyTiger
all not work latest update! developers crash///
