分页: 36 / 49
发表于 : 07 1月 2022, 14:16
发表于 : 26 6月 2025, 06:19
Perhaps because of translation and did not understand the problem correctly.
When using a font, the height position of the ‘:’ separator relative to the rest of the text is determined only by the font itself. The preview editor uses a font similar to the system font in the clock, but there may be slight inaccuracies.
When using the font to display AM/PM on the clock, there is a toggle on the right side of the clock. It also depends on the time settings in the clock.
In your case, if the clock has a 12-hour time format, the AM/PM lettering will not fit in the text block. This may affect its alignment.
If you want the separator to always be in the middle of the screen, using a font will not work. Even if you enable the display of leading zeros the length of the caption will vary slightly. This is because the numbers have different widths.
发表于 : 26 6月 2025, 13:37
Emiliomc
I think I understand what you're saying. But I have some doubts about whether we're talking about the same thing. I've attached two images. Image "01" would be how I'd like the height of the ":". However, the height of the ":" is ultimately like image "02." That is, at the same level as the hour digits. Are we talking about the same thing, and therefore it can't be solved by using a third-party font?
发表于 : 26 6月 2025, 14:47
@Emiliomc
This can be solved with a third-party font. But you need to find a font with a similar style of numbers and display «:» above. Or edit the font so that the «:» symbol is displayed above. I haven't done this myself, but I know there are utilities for editing fonts. I don't think it will be difficult to simply move the symbol.
Or you can use a set of images instead of a font. User @TRK88PL has created a good utility that makes it easier to create the necessary images.
发表于 : 26 6月 2025, 21:52
frankh93
SashaCX75 写了: 26 6月 2025, 14:47
@Emiliomc
What about my issue? is there a chance to hide AM/PM thing when using a font file? cause when the phone clock is in 24hr format the center alignment works fine, the issue only comes when the clock is in 12hr format. Managed to hide it reducing the height but still the alignment gets a bit to the left. I don't mind if the separator ":" isnt centered, I just want the whole clock to be centered in both formats (12H/24H)
发表于 : 27 6月 2025, 07:25
frankh93 写了: 26 6月 2025, 21:52
Edit the packed dial. Find these lines in it and replace them with an empty line.
发表于 : 27 6月 2025, 08:57
We do not use the 12-hour time format. Therefore, I do not know the specifics of its use. How common is it to display only numbers without AM/PM designation. I don't think it is common. That is why there is no option to switch it off in the editor.
And as I wrote in the post above you can use a set of images instead of a font. If there are no necessary images they will not be displayed.
发表于 : 27 6月 2025, 14:17
Imozeb
I created a watch face in version 13.2 for my Bip 5.
I used distance -> text font option to display the distance. and units
The units are stuck in kilometers and the units do not respect changing the units to imperial (miles) from the Zepp app.
I confirmed that this is not a bug with the Bip 5 firmware because other watch faces allow switching between distance units (both some older ones made in this software and ones made in other software).
发表于 : 27 6月 2025, 16:52
frankh93
SashaCX75 写了: 27 6月 2025, 08:57
Could you tell me how to edit the packed watchface? Can I edit the index.js just uncompressing it? I would be thankful if you tell me how. About how common is to hide the AM/PM over here, it is pretty common cause sometimes we skip the AM/PM thing when reading the clock. Is it possible you add an option to hide it, please?
发表于 : 27 6月 2025, 17:21
Emiliomc
SashaCX75, thank you so much for the suggestions on how to resolve the height of the ":" characters. I couldn't figure it out with the app from my colleague, which is very interesting. But I found an app to edit .ttf files and increase the height of the ":" characters. It's called FontForge. Easy to use for my purposes.
On another note, I'm having a problem creating a watchface on my GTS 4. I think the topic was discussed in the forum, but I can't find it. My GTS 4, for example, tells me the distance traveled is 2.14 km, yet the watchface shows 2.10 km. There's always a slight difference, which isn't the case with other values ​​like BPM, calories, steps, etc. My question is if, in relation to distance, this could be corrected by editing the index.js file created with the watchface, and if so, how?
发表于 : 27 6月 2025, 17:38
@Imozeb
I replied to you on GitHub. I reported the issue to the developers. The simplest option is not to use the font, but to use a set of images instead.
发表于 : 27 6月 2025, 17:42
@frankh93
You can open the watch face with any archiver. It is a regular zip archive. You can edit the files directly in it. In any text editor, find the text AM or PM enclosed in quotation marks and simply delete it, leaving the quotation marks. It is advisable to have basic programming knowledge so as not to delete anything unnecessary.
发表于 : 27 6月 2025, 17:53
Emiliomc 写了: 27 6月 2025, 17:21
I haven't heard of such a problem. I use steps rather than distance myself. That's why I haven't noticed anything like that either.
There are several types of distance widgets. Try using ‘Values in a circle’ or ‘Values at an angle’. These two types use a different method of displaying data.
发表于 : 28 6月 2025, 23:29
Guydu91
SashaCX75 写了: 27 6月 2025, 17:53
I don't think there's really a perfect answer to this question...
Indeed, apart from sports activities requiring GPS (running, cycling, swimming, etc.), smartwatches don't use any GPS data, and therefore the distances displayed on the watch are simply a calculation of the number of steps multiplied by an arbitrary value of one step (from what I understand: 0.65 m).
Since each individual is different (height, body type, walking style, etc.), the watch will provide approximate distance values.
However, the number of steps is recorded by the watch's pedometer and is a slightly more reliable value.
Be careful, however, I've noticed that pushing a lawnmower, a supermarket cart, or a child's stroller distorts the step recording: they simply aren't counted because the arm isn't swinging.
Another funny thing: parking in a car can count steps... even when you're sitting down!!
Other information: calories are also the result of a calculation and not an actual count.
In conclusion, the information provided by our watches is more indicative than anything else and reflects an activity whose evolution can be seen over time.
发表于 : 29 6月 2025, 03:57
frankh93
SashaCX75 写了: 27 6月 2025, 17:42
@frankh93
Cool, thank you. I was able to modify the file and got it working.
Btw I made another one before, it was supposed to have the min and max heartrate values but as the tool doesn't have it I wasn't able to add it... Is there a chance you add these values?
发表于 : 29 6月 2025, 09:41
@Guydu91 It doesn't matter how accurately the watch calculates the distance. In any case, regardless of the display method, this number should be the same. I checked this. And when displaying in font, the last digit is always 0. This is a firmware error. I also found that when displaying values at an angle and values around the circumference, they are always displayed in kilometres. This is an editor error and will be fixed in future versions.
发表于 : 29 6月 2025, 09:42
frankh93 写了: 29 6月 2025, 03:57
This is not planned for upcoming versions.
发表于 : 29 6月 2025, 15:35
Version 14.0
Mirror
发表于 : 29 6月 2025, 16:30
rush2112
@SashaCX75
发表于 : 29 6月 2025, 17:15
frankh93
SashaCX75 写了: 29 6月 2025, 09:42
It is not? May I ask why?
Btw thank you so much for the new version
发表于 : 29 6月 2025, 17:37
frankh93 写了: 29 6月 2025, 17:15
Because there isn't enough time for everything
发表于 : 01 7月 2025, 09:57
Imozeb
I noticed that the calories burned for walking on my Bip 5 is very inaccurate. Is there any way to pull distance from the watch as a float and use my own algorithm to calculate my own calories to display (not overwriting their calorie calculation, but just displaying what my algorithm calculates)?
发表于 : 02 7月 2025, 04:07
@Imozeb
https://docs.zepp.com/docs/watchface/ap ... /DISTANCE/
But if your algorithm is based on distance alone, it will be even less accurate.
发表于 : 02 7月 2025, 10:45
Imozeb
So after reading the docs, I think I partially understand.
Just two questions:
1. Am I correct that to add custom text, calculations, etc, I would export the watch face from your software and then edit the json file to add my custom scripts?
2. The docs do not mention math functions at all. Do you know if it is possible to implement simple math to calculate my own calories burned? For example, simple addition, multiplication, division of variables like HR, distance, and constants.
If I get this working and tracking closer to what should be more accurate (eg papers on Apple Watch calories burned), I can provide my script to the community if you wanted to implement it. The final goal would be to get more accurate walking and running calories based off better equations that match more closer to an Apple Watch.
发表于 : 02 7月 2025, 17:21
@Imozeb
1. To add your code to the watch face, you can edit the js file in the compiled watch face or add the code via the editor. The first method is more convenient if you need to edit and debug the added code. The second method is easier if the code has already been tested and only needs to be slightly modified for the new project.
2. You can use any mathematical functions available in JS.
发表于 : 03 7月 2025, 01:01
Imozeb
I've tested a couple things tonight and found that if I unzip and then rezip the watchface package generated by your program (without editing the index.js file), it won't upload to my watch anymore, so I may have to go with the second route which is adding the code via the editor. However, it looks like there are several places that I could add the code. Is there any documentation as to which of the several .js files to use for different types of code (e.g. functions, hmUI.createWidget, calling sensors etc)?
For a test, I want to simply read the distance sensor, add a constant value of 10 to it and print that to the watchface below the real distance. If I can successfully do this test, I can figure out the rest for sure. I am just not sure which .js file in the editor I should add the different sections of code to.
