Page 4 of 24
Posted: 17 Dec 2019, 17:06
by SashaCX75
Version 10.0
Updated translation.
Fixed work with Verge Lite
Fixed Italian translation.
Added Chinese manual.
Bugs fixed.
Added a manual in English.
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
Added support for T-Rex.
Added support for shortcuts.
Added support for languages (Portuguese, Czech, Slovak, Hungarian).
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal:
[email protected].
Re: GTR_WatchFace editor for Windows by SashaCX75
Posted: 15 Feb 2020, 17:00
by murigny64
Here is new GTR_Watchface editor 6.0 by SashaCX75
Great app !
thx to SashaCX75
Download here:
https://drive.google.com/file/d/1UvfCIP ... sp=sharing
Posted: 18 Feb 2020, 20:37
by osmat
Version: 6.1
Short Description: Graphic editor for working with Amazfit GTR / GTS / T-Rex dials
The version (without puthon) differs from the regular version only in the utility for unpacking bin files that comes bundled and does not require python installation (it may not work on 32-bit systems).
Note: the path to the program should not contain Russian letters, it is advisable to unpack it to the root of the disk.
If the bin file is not created, and the log file has the entry "bad transparency mask", this means that the format of one or more images is incorrect. You can fix it as follows:
- in Photoshop - Save for web -> Preset PNG-24
https://cutt.ly/QrNUVvF
Posted: 19 Feb 2020, 16:18
by pv_sa
Hi all,
[mention]osmat[/mention] Thank you for the version 6.1, with this one I could edit a WF this morning and was super easy.
I ask a little help regarding the compression/packing. I edited a existing WF, adding other elements, like Calories and distance, etc.
It worked fined the virst version, but as I kept adding the features (steps, heart rate) and from other WF I got the weather icons.
Butduring the packing process, 2 lines appear in the console. "Unknown Watchface 16", wrote two times, see image 1.
After that I get the message "Uncompressed file size exceeds 1.95MB. Dial may not work", see image 2.
My package is 2.44MB, the compressed is 220 kB.
Is there something I could do? I tried removing each feature I was adding but couldn't get it working properly again.
Also attached are the previews for the watchface.
Any help is appreciated, thanks a lot in advance.
Posted: 19 Feb 2020, 16:55
by SashaCX75
The message "Unknown Watchface 16" appears when there are shortcuts in the project - do not pay attention.
You can reduce the project by reducing the number of pictures or out of the size in pixels. Disabling individual functions has virtually no effect on size.
Posted: 19 Feb 2020, 17:08
by pv_sa
[mention]SashaCX75[/mention] Thanks a lot for the explanation! I'm right now trying to reduce it.
I noticed that there were a lot of copies of the days of the week (Monday, Tuesday, etc) I deleted those and I'll try to reduce the size of the status icons also.
Is there any other tips you suggest to reduce it?
Obs. I could "Install" the oversized version, but I can only see the hours and the icons of the background, nothing more, and afte around 30min, the watch started vibrating continuously and them restarted. After some tries I could restart it and put a official watch face, but maybe this can indicate something. Just reporting, might help in some way.
Again, thanks a lot for the help!
Posted: 19 Feb 2020, 17:59
by SashaCX75
pv_sa wrote: 19 Feb 2020, 17:08
The number of pictures to display the day of the week can be reduced to 7 (sometimes there are 21).
In addition to reducing the number of images and their size in pixels, I do not know other ways to reduce the file size. Trying to optimize PNG files does not make sense. When saving to a bin file, they are still converted to another format.
Posted: 19 Feb 2020, 18:25
by pv_sa
Thank a lot [mention]SashaCX75[/mention].
While trying to reduce the size some minues ago. It started bootlooping, going only until the log, give a little sinal of vibration, then the screen turns black. I read in the link bellow that you can hard reset the watch to the QR code by pressing the two buttons, but its not working.
https://forum.xda-developers.com/smartw ... p-t3963953
Do you have any idea what could have happened or a suggestion on how to fix this?
Should have let the pros handle this watch face stuff... sh!t... I'm only 2 weeks with the watch.
Again, thanks for the help
Posted: 19 Feb 2020, 18:31
by pv_sa
Found the fix for the bootloop!
https://forum.xda-developers.com/smartw ... p-t4016561
its fixed. for fix it, put to charge. go to amazfit app and change the watchface for one of the app and it fixed itself. use this if someone have this problem
This solved my problem! Hope it help others!
Posted: 23 Feb 2020, 22:06
by Lordalpine
pv_sa wrote: 19 Feb 2020, 18:31
You can just totally kill the preview PNG, if it's not already done.
Put a 1pixel X 1Pixel picture and name it 0001. [ if you want to make it later and to pack with 0001 inside the package ]
or don't use it [ It's allowed by the Gui tool so why not^^.... ]
User will understand if you explain on the description why there's no preview [ Gain space ]
Posted: 24 Feb 2020, 18:20
by chazey2
Hi guys, I'm messing around to try just adapting a pre made face just for my own use only. I've added shortcuts and copied and pasted the shortcut part of Json from another pre made face with shortcuts. I can see when adjust my shortcut placement the Json file adjusts to the new placements I make (x,y)
When pack I get two files 1 .bin file and one _packed.bin I've tried loading both on the watch it either goes to pre made face without my changes or the original amazfit that I over wrote the bin file in.
Any pointers please.
As I say not trying to copy others hard work would just like adapt my favourite face (Focused smoke v2 by nightwatch) as I have poor eyesight without my glasses and I can see the time etc without glasses.
Posted: 24 Feb 2020, 19:07
by SashaCX75
1. Unpack the dial
2. In the section "Shortcuts" include the necessary
3. Save the json file
4. Pack the dial
5. In the folder with the unpacked dial you find the file name_packed_zip.bin or name_packed.bin and install it on the watch
Posted: 24 Feb 2020, 19:13
by chazey2
Thanks Sasha will give it a go again.
Posted: 24 Feb 2020, 22:23
by pv_sa
Lordalpine wrote: 23 Feb 2020, 22:06
Thanks a lot for the tip [mention]Lordalpine[/mention], this for sure will save a lot of space in my next WF, great tip!
Posted: 24 Feb 2020, 22:27
by chazey2
SashaCX75 wrote: 24 Feb 2020, 19:07
1. Unpack the dial
4. Pack the dial
Many thanks got it working
Posted: 26 Feb 2020, 15:40
by shirumitsu
Hello, when I try to create the watchface .bin file I created this error appears, what can it be? the editor's folder from Sasha is in the root folder D:, already installed python, use win10
[fatal] [WinError 2] the system cant find arquive...
Posted: 26 Feb 2020, 16:58
by SashaCX75
If a dialog box pops up with an error, then it is better to attach a screenshot of this window with an error so that it is clear what is at stake. You can try resetting the program.
If the bin file is simply not created, but there is a log file, then you need to look in it.
Posted: 26 Feb 2020, 22:30
by shirumitsu
SashaCX75 wrote: 26 Feb 2020, 16:58
please see the image, language portuguese, i can unpack a bin but i cant save my wf to .bin
Posted: 26 Feb 2020, 23:08
by shirumitsu
2020-02-26 20:00:51,882 - root - DEBUG - Generating states done...
2020-02-26 20:00:51,898 - root - CRITICAL - bad transparency mask
File "program.py", line 71, in writeWatchFace
File "program.py", line 181, in generatePreviews
File "watchFaceParser\previewGenerator.py", line 16, in createImage
File "watchFaceParser\previewGenerator.py", line 25, in createFrame
File "watchFaceParser\models\elements\basic\containerElement.py", line 12, in draw3
File "watchFaceParser\models\elements\common\imageElement.py", line 22, in draw3
File "watchFaceParser\models\elements\common\imageElement.py", line 30, in draw2
File "site-packages\PIL\Image.py", line 1524, in paste
ValueError: bad transparency mask
2020-02-26 20:00:51,914 - root - ERROR - [WinError 2] O sistema não pode encontrar o arquivo especificado: 'D:\\GTR_Watch_face_(without_Python)\\Watch_face\\Nova\\sonic_packed.bin'
During handling of the above exception, another exception occurred:
File "program.py", line 116, in packWatchFace
File "program.py", line 80, in writeWatchFace
FileNotFoundError: [WinError 2] O sistema não pode encontrar o arquivo especificado: 'D:\\GTR_Watch_face_(without_Python)\\Watch_face\\Nova\\sonic_packed.bin'
File "main.py", line 39, in <module>
File "program.py", line 118, in packWatchFace
Posted: 27 Feb 2020, 14:15
by rubiales41
hello, can someone tell me, what to do to put the hands of the clock, when the clock is on one side of the dial, I do not get it, when I keep to see the result, the needles walk around the dial
Posted: 27 Feb 2020, 14:56
by SashaCX75
[mention]shirumitsu[/mention]
The main message that indicates an error
The solutions are
listed here.
Posted: 27 Feb 2020, 15:06
by SashaCX75
[mention]rubiales41[/mention]
If I understand correctly, you need to move the clock hands from the center of the dial.
For this there is a parameter "Axis offset"
Posted: 27 Feb 2020, 20:35
by Lordalpine
Put time at Midnight / 00:00
-> Easiest position to adjust [ For other hand like battery // heartrate it work the same ]
Select White Grid or black grid [ It's a nice help to make perfect Hand turn ]
Center of the Hand perfectly centered
Center Minute Hand [ X horizontal // Y Vertical ]
Axis Offset is where you want to put the hand [ Hour and Minute Here : X 133 // Y 219.... so my hour and minute hand are placed on the right ]
Some advice : Look how much pixel is your center of hand...
Here It's a 3 pixel created from scratch[ So It's easy^^ ]
-> Center of background is 227 [ 454*454 background right ? ]
-> Put a pixel horizontal size with paired number [ 20 // 22 // 24 // 26 etc... ] and put the hand one pixel on the left on your PNG
or
-> Put a pixel horizontal size with unpaired number [ 21 // 23 // 25 // 27 etc ] and center the hand on your PNG
Just writing this because, when you want to make a face already existing for other device... the hand are not scaled, and when you resize them...
Center Hand pixel and all the pixel are splitted on two [ Then It's Harder to edit for colour variant for exemple ]
4/6/8/10 pixel Horizontal hand size will be 1 pixel on the left or 1 pixel on the right.... [ It will make you mad^^ ]
Or the Hand are not really really 100% centered when they turn...
The advice is to get Pixel align [ and not splitted in two on PNG ] and perfect align on face
[ and sometimes you loose time because you forget this ]
Posted: 28 Feb 2020, 10:33
by shirumitsu
SashaCX75 wrote: 27 Feb 2020, 14:56
@shirumitsu
The solutions are
listed here.
great! work here, but how create a animation? i have 4 frames
Posted: 29 Feb 2020, 15:26
by SashaCX75
shirumitsu wrote: 28 Feb 2020, 10:33
The editor does not currently support animation.
Animation can be added manually by editing the json file. What the animation section should look
like here.
Posted: 29 Feb 2020, 19:48
by rubiales41
hello, how is it done, or where can I find the time points and minutes to make analog clocks ?, thank you very much
