Сторінка 25 з 26
MiBandWFTool
Додано: 08 липня 2019, 12:57
lvpokka
Author
lvpokka
Tool Description
How to
History log
What's new
  • added animation support
  • fixed pulse and weather
  • analog clock support
ver1.2
ver1.3
ver1.3.2
- bug fixes
ver1.3.3
Stable v1.3.6
- palette mode fix
Stable v1.3.7
Stable v1.3.8
- Fixed display bugs
v1.3.9
- Calories rendering fixed
v1.4.1
- Other bugfixes
- New WF support
v2.1.4
- BugFixes
v2.1.5
- Preview bugfixes
Mi Band 4 WF Tool
v1.4.2
- Added miles image support
NOTE:
Mi Band 5 WF Tool
v2.1.6
- Preview bugfixes
Mi Band 6 WF Tool
v4.1.0
- Added Lunar calendar
- Bug fixes
MiBandWFTool_4.1.0.zip
Re: MiBandWFTool
Додано: 10 травня 2021, 11:16
Walker_Alan
lvpokka писав: 10 травня 2021, 08:14
I will not add items that are not in stock of the watchfaces
Not sure if I understand you right. What do you mean by stock? Do you mean default watch faces that are initially included? If so, then it is there: https://www.giztop.com/media/catalog/pr ... _6-2_1.jpg
Let's make your tool even more awesome by adding that progress. If I can help with that somehow, I would be happy to :)
Re: MiBandWFTool
Додано: 10 травня 2021, 14:10
lvpokka
Walker_Alan писав: 10 травня 2021, 11:16
No, stock its which you can download from official.
This is the image you showed is not Watchface, its program and not connected with watchface at all
Re: MiBandWFTool
Додано: 12 травня 2021, 00:35
gmontes
Hi guys, i am getting a problem making an animated Watchface:
https://amazfitwatchfaces.com/mi-band-6/view/203
Зображення
The animation is playing, but the other layers of the animation are still on screen "ghosting" it. What mistake i made? I used this https://amazfitwatchfaces.com/mi-band-6/view/160 animation as a start.
Re: MiBandWFTool
Додано: 12 травня 2021, 02:35
Sladeth
hi, i have a problem with the tool (4.1.0) When I load images in the batteryicon (which do not have a background and are PNG) when compiling it comes out perfect in the gif but in my Mi band 6 it fills the background with a blue color :c
Re: MiBandWFTool
Додано: 12 травня 2021, 08:42
lvpokka
gmontes not a mistake, use background for all animations)
Sladeth don't use palette mode for this type of images, probably it was compressed
Re: MiBandWFTool
Додано: 12 травня 2021, 18:18
Sladeth
lvpokka thanks! the palette mode was deactivated so I activated it and with that the bug went away, but I have another problem (which I also had before :)) the images/animation of the step advance does not appear at the beginning of the progress, the first image does not appear (it does not appear before approximately 800 steps) D: but it does in the gif preview
Re: MiBandWFTool
Додано: 19 травня 2021, 17:39
Sladeth
is there a place where i can upload my project to get help? can i upload here? (btw it has nintendo copy_right images)
Re: MiBandWFTool
Додано: 23 травня 2021, 06:39
changuanwei
anyone know how to make the face preview when changing faces on mi band 6. my watch faces are not showing when i choose between the 3 custom faces on my mi band 6.
Re: MiBandWFTool
Додано: 24 травня 2021, 03:48
风雨透
Hoekstra писав: 05 травня 2021, 20:10
TedwardCz писав: 05 травня 2021, 15:41
Some good news! I tinkered for about a dozen iterations, and finally got the TimeZone1 and TimeZone2 to work. I have no idea what I did that finally resolved it, but it's now working. Next trick, and this one would be really nice, is to get the UV index working. Currently, when I add the properties for UVIndex, the entirety of the Weather property breaks (doesn't display). In comparing UVIndex to Wind (which is working), I notice that the syntax is a bit different. Wind has "Wind{Text{data},ImageSuffixEn}" whereas UVIndex has "UVIndex{UV{Text{data},SuffixImageIndex}}". When I make UVIndex's syntax match Wind's, the packer throws an error, though. Anyway, if you'd be willing to take a peek, I'm including a Google Drive link. contrast3 (no UVI) works, contrast4 (with UVI) does not.
https://drive.google.com/drive/folders/ ... sp=sharing
There was something with UV/Wind not working together with temperatures or something.
Is there any solution?
Re: MiBandWFTool
Додано: 30 травня 2021, 14:12
Artties
Hi, I have a quick question. Is there a way to make an element to be on top of another? For example I want the am/pm to be on top of battery percentage indicator, so that if I use 12r time format on my band, am/pm will appear and when I switch to 24hr time format, am/pm will disappear thus reveal the battery percentage under it.
Re: MiBandWFTool
Додано: 07 червня 2021, 19:18
yaoun
HI,
I would like to know if there an error with the "PAI" on our watchfaces.
I have noticed on 2 different watchfaces from this site that if the PAI is above 250 (or 256....), the watchfaces show a wrong number.
I think that there is perharps a problem with the number of bytes possible.
Have you notices the same things?
Thanks a lot for your work.
Re: MiBandWFTool
Додано: 15 червня 2021, 19:02
nsiolios
23ll писав: 18 серпня 2020, 00:26
diopter писав: 13 серпня 2020, 21:45
SEDO is absolutely right, there is a bug, and not only with the heart rate, but with all progress indicators.
The internal MI WFs already show the first progress step (blue for heart rate), while our custom WFs still show nothing.
My workaround is also to put the respective first image on the background.
I am thinking to do like that as well, but I don't like the fact the first indicator will be always on also if heart rate is not recognised :|
I am trying to do a step progress bar with 12 segments. when the internal MI WFs show the first and second segment my WF shows nothing. Also when the internal MI WFs show the last progress step, my WFs show the 11th segment and never shows the 12th segment . Although the gif animation that produces the WatchFace.exe all the segments work perfect and as expected.
Any idea why it happens ? is it bug of Mi Band 5 or something else ?
Re: MiBandWFTool
Додано: 15 червня 2021, 19:20
nsiolios
Sladeth писав: 12 травня 2021, 18:18
@lvpokka thanks! the palette mode was deactivated so I activated it and with that the bug went away, but I have another problem (which I also had before :)) the images/animation of the step advance does not appear at the beginning of the progress, the first image does not appear (it does not appear before approximately 800 steps) D: but it does in the gif preview
I have the same problem and I can't understand why or how to solve :(
Re: MiBandWFTool
Додано: 02 липня 2021, 05:10
HCt
感谢分享,兄弟
Re: MiBandWFTool
Додано: 06 серпня 2021, 14:46
Dijkmeneer
I am making a animated watchface. but when i upload it to my watch my steps, heartrate, kcal and pai are not showing, the number arent there.
The bin file is attached and example photos
Зображення
Зображення
Re: MiBandWFTool
Додано: 08 серпня 2021, 18:14
ajulraj
Hi, is there any argument we can give to Watchface.exe to only generate the .bin File? And exclude the animations and previews?
Re: MiBandWFTool
Додано: 26 серпня 2021, 21:19
slibbinas
Hi, after decompressing and compressing back (even without the modification) any of watchfaces I can't get preview image on Notify for Miband upload screen. It says can't retrieve preview image. Also I can't change to that watchface back on the band iself. So definitely something is with preview img. Where could be the issue ?
Re: MiBandWFTool
Додано: 17 вересня 2021, 08:15
plasticninjaguy
Hi, thanks for your constant work on this tool.
Unfortunately, I am having an issue with version 4.1.0 for the mi band 6, that is whenever I unpack a bin file and then recompile from the json file, it seems to destroy most of the display functionality of the watch face, specifically, the weather information and the am/pm display. After unpacking I did not alter the files in any way I simply repacked and the issue was present.
Re: MiBandWFTool
Додано: 21 листопада 2021, 07:30
carlgemsss
Hi. I can't download the v4.1.0 using the provided link. Can you provide an alternative/mirror link? Thank you very much!
Re: MiBandWFTool
Додано: 26 листопада 2021, 11:29
mostafaz4
I'm trying to decompile and recompile this custom watchface , but weather info disappears in the band even though I didn't change anything, just decompile and recompile, I think it is a compiler bug that can't handle all weather data being together, but if it is, how can the creator of that custom watchface compile it without breaking weather data?
Is there a workaround that can achieve this?
Re: MiBandWFTool
Додано: 28 листопада 2021, 17:04
angulito
lvpokka Hi, first of all, thanks for your work here, it's amazing. I have some questions where I would appreciate your input:
- is there any way to reorder layers in z-index?
- my current images are being transformed from 8-bits depth to 32-bits. Is there any way to keep the original format? Otherwise I am getting troubles with final size.
- I wonder if your code is already publicly accesible (or if it could be) so we might help to investigate further these kind of questions.
Thanks a lot in advance,
Natalia.
Re: MiBandWFTool
Додано: 29 листопада 2021, 12:55
angulito
Another question lvpokka , do you know if there is any way to reuse the same image on weather or months icons? I wonder if instead of needing to specify imageIndex and indexCount, we could specify an array of image index (where we can point to the same image and reuse it).
Thanks again,
Natalia.
Re: MiBandWFTool
Додано: 29 листопада 2021, 22:14
mostafaz4
mostafaz4 писав: 26 листопада 2021, 11:29
I found the solution, there is a bug in the compiler that can be patched using hex editors on the generated ".bin" files
The problem: the tool writes hardcoded header to the generated .bin files that caused my issue.
Solution: You have to edit the generated .bin file and change bit number 80 to "þ"
Solution tutorial using notepad++: change the character in the picture by this character "þ"
Original:
Зображення
Patched:
Зображення
Re: MiBandWFTool
Додано: 14 грудня 2021, 12:04
lvpokka
mostafaz4
Which bug, can you explain more?
how did you find this problem?
how did you found solutions for you bug?
Why not "ÿ" like FF?
Weather is working ok for other peoples
angulito
1) no z-index
2) read readme, use raw mode not palette
3) no public code
Re: MiBandWFTool
Додано: 22 грудня 2021, 08:30
mostafaz4
lvpokka
The tool contains a fixed hardcoded bin header that is pasted on any generated watchface, I assume there is a property that states how many JSON keys are used, which becomes a problem when you exceed this key amount.
I was trying to modify the mentioned watchface, but weather data get corrupted even if I just decompile and recompile it without modifying anything.
I compared the generated bin with the other watchface that is working correctly and I found that they are identical except for that byte I mentioned.
Well, I just copied that byte as-is from the working watchface, maybe "ÿ" would work too, the tool should count and report the right amount of JSON keys to the header.
Weather normally works if you select some info but not all, if you select all weather info it won't work.
