Page 3 of 24
Posted: 17 Dec 2019, 17:06
by SashaCX75
Version 10.0
Updated translation.
Fixed work with Verge Lite
Fixed Italian translation.
Added Chinese manual.
Bugs fixed.
Added a manual in English.
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
Added support for T-Rex.
Added support for shortcuts.
Added support for languages (Portuguese, Czech, Slovak, Hungarian).
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal:
[email protected].
Re: GTR_WatchFace editor for Windows by SashaCX75
Posted: 04 Feb 2020, 15:35
by SashaCX75
As far as I know, either the current temperature or the temperature during the day or night can be displayed. They cannot be displayed at the same time.
Who cares GTR_Watch_face_(without_Puthon)_5_2
https://drive.google.com/open?id=1T8u_f ... vW6vtZc-c8
Posted: 04 Feb 2020, 19:11
by SashaCX75
New version of GTR/GTS WatchFace editor v6.0
List of changes (google translation)
https://drive.google.com/open?id=1Sn5oh ... elbtYCx4CS
Posted: 07 Feb 2020, 22:26
by yinas
hey hello.
i already read in this thread regarding, exceeding 1.5MB file size of BIN file.
but i do not want to accept that it depends on visual PNG x*y size...
feels like the packing of the editor is off in some place.
i know how to design the layout, and handle PNGs in a way that file size is minimal with desired visuals.
but this should not be the duty of the designer to be limited to something way smaller than the available screenspace.
currently my actual PNG file sizes are smaller than in some other watchfaces using smaller actual screen estate, and definitely smaller than the largest used fonts for custom watchfaces that still seem to work (but dont have complications).
this does not work:
maybe someone has an idea how to optimize, while still retaining the desired layout and function?
i added a new 1.1 version with smaller main clock font, since the larger one breaks the watchface and even caused bootloop... but i left the original file still within the watchface post.
this works:
this is my watchface post:
https://amazfitwatchfaces.com/gts/view/949
any chance the packing of the bin will be optimized in future versions, to properly allow for all possible combinations of PNGs, aka allowing to use the full screen whichever way imaginable?
thanks for input!
br
Posted: 08 Feb 2020, 08:53
by Zaslon
Does anyone know how to resolve the "ValueError: bad transparent mask" error during compilation?
I uses GTR/GTS WatchFace editor v6.0 for GTR 42mm.
Posted: 08 Feb 2020, 09:13
by yinas
Zaslon wrote: 08 Feb 2020, 08:53
Had the same issue when I tried to force compress my PNGs with eg. "PngOptimizer".
Check the images you use in your watchface, and ideally save them properly as PNG via something like Photoshop or GIMP.
Posted: 08 Feb 2020, 14:37
by shirumitsu
anyone post any tutorial vídeo how create a watch face with this program?
Posted: 08 Feb 2020, 14:46
by maikeandre
shirumitsu wrote: 08 Feb 2020, 14:37
The software is so much easy to do. Try use it. I suggest you to get one whatch from site (a simple) and open it in editor. This is the best way to be a master!
Posted: 08 Feb 2020, 14:58
by 999Nocturne
maikeandre wrote: 08 Feb 2020, 14:46
Sorry but the program does not manage the animation?
Posted: 08 Feb 2020, 18:12
by maikeandre
999Nocturne wrote: 08 Feb 2020, 14:58
Not yet.
Posted: 08 Feb 2020, 18:50
by SashaCX75
This usually happens when there are 8-bit pictures.
Posted: 09 Feb 2020, 02:55
by Zaslon
SashaCX75 wrote: 08 Feb 2020, 18:50
Now I try changing images to PNG-8/PNG-16 but both cause the error.
I use the Affinity Designer but this might be not gfood.
I'll try something else. Thank you!
Posted: 09 Feb 2020, 08:50
by SashaCX75
Zaslon wrote: 09 Feb 2020, 02:55
PNG-8 - definitely not working
PNG-16/24 - it doesn't work for me, but some people write what works
PNG-32 - works fine
You can lay out the source, try to see why it does not work.
Posted: 10 Feb 2020, 07:31
by Zaslon
SashaCX75 wrote: 09 Feb 2020, 08:50
PNG-32 - works fine
I checked Affinity forum and finally I got the core of this problem.
My background image's background
filled with black colour so there's no transparent area.
It causes 32bit PNG changed into 24bit PNG as no alpha channel automatically.
I changed some images into 32bit PNG, It works!
Posted: 11 Feb 2020, 10:32
by shirumitsu
this program work on windows 10? here i cant use, any bug
Posted: 11 Feb 2020, 14:48
by Horatius80
shirumitsu wrote: 11 Feb 2020, 10:32
The editor must be in the root C:\GTR_watchface_editor .... or D:\GTR_ .... and better run it on 64bit OS ... I have Windows 10 64bit in root of "D" disk and it works perfectly without any problems ...
Posted: 15 Feb 2020, 17:00
by murigny64
Here is new GTR_Watchface editor 6.0 by SashaCX75
Great app !
thx to SashaCX75
Download here:
https://drive.google.com/file/d/1UvfCIP ... sp=sharing
Posted: 18 Feb 2020, 20:37
by osmat
Version: 6.1
Short Description: Graphic editor for working with Amazfit GTR / GTS / T-Rex dials
The version (without puthon) differs from the regular version only in the utility for unpacking bin files that comes bundled and does not require python installation (it may not work on 32-bit systems).
Note: the path to the program should not contain Russian letters, it is advisable to unpack it to the root of the disk.
If the bin file is not created, and the log file has the entry "bad transparency mask", this means that the format of one or more images is incorrect. You can fix it as follows:
- in Photoshop - Save for web -> Preset PNG-24
https://cutt.ly/QrNUVvF
Posted: 19 Feb 2020, 16:18
by pv_sa
Hi all,
[mention]osmat[/mention] Thank you for the version 6.1, with this one I could edit a WF this morning and was super easy.
I ask a little help regarding the compression/packing. I edited a existing WF, adding other elements, like Calories and distance, etc.
It worked fined the virst version, but as I kept adding the features (steps, heart rate) and from other WF I got the weather icons.
Butduring the packing process, 2 lines appear in the console. "Unknown Watchface 16", wrote two times, see image 1.
After that I get the message "Uncompressed file size exceeds 1.95MB. Dial may not work", see image 2.
My package is 2.44MB, the compressed is 220 kB.
Is there something I could do? I tried removing each feature I was adding but couldn't get it working properly again.
Also attached are the previews for the watchface.
Any help is appreciated, thanks a lot in advance.
Posted: 19 Feb 2020, 16:55
by SashaCX75
The message "Unknown Watchface 16" appears when there are shortcuts in the project - do not pay attention.
You can reduce the project by reducing the number of pictures or out of the size in pixels. Disabling individual functions has virtually no effect on size.
Posted: 19 Feb 2020, 17:08
by pv_sa
[mention]SashaCX75[/mention] Thanks a lot for the explanation! I'm right now trying to reduce it.
I noticed that there were a lot of copies of the days of the week (Monday, Tuesday, etc) I deleted those and I'll try to reduce the size of the status icons also.
Is there any other tips you suggest to reduce it?
Obs. I could "Install" the oversized version, but I can only see the hours and the icons of the background, nothing more, and afte around 30min, the watch started vibrating continuously and them restarted. After some tries I could restart it and put a official watch face, but maybe this can indicate something. Just reporting, might help in some way.
Again, thanks a lot for the help!
Posted: 19 Feb 2020, 17:59
by SashaCX75
pv_sa wrote: 19 Feb 2020, 17:08
The number of pictures to display the day of the week can be reduced to 7 (sometimes there are 21).
In addition to reducing the number of images and their size in pixels, I do not know other ways to reduce the file size. Trying to optimize PNG files does not make sense. When saving to a bin file, they are still converted to another format.
Posted: 19 Feb 2020, 18:25
by pv_sa
Thank a lot [mention]SashaCX75[/mention].
While trying to reduce the size some minues ago. It started bootlooping, going only until the log, give a little sinal of vibration, then the screen turns black. I read in the link bellow that you can hard reset the watch to the QR code by pressing the two buttons, but its not working.
https://forum.xda-developers.com/smartw ... p-t3963953
Do you have any idea what could have happened or a suggestion on how to fix this?
Should have let the pros handle this watch face stuff... sh!t... I'm only 2 weeks with the watch.
Again, thanks for the help
Posted: 19 Feb 2020, 18:31
by pv_sa
Found the fix for the bootloop!
https://forum.xda-developers.com/smartw ... p-t4016561
its fixed. for fix it, put to charge. go to amazfit app and change the watchface for one of the app and it fixed itself. use this if someone have this problem
This solved my problem! Hope it help others!
Posted: 23 Feb 2020, 22:06
by Lordalpine
pv_sa wrote: 19 Feb 2020, 18:31
You can just totally kill the preview PNG, if it's not already done.
Put a 1pixel X 1Pixel picture and name it 0001. [ if you want to make it later and to pack with 0001 inside the package ]
or don't use it [ It's allowed by the Gui tool so why not^^.... ]
User will understand if you explain on the description why there's no preview [ Gain space ]
Posted: 24 Feb 2020, 18:20
by chazey2
Hi guys, I'm messing around to try just adapting a pre made face just for my own use only. I've added shortcuts and copied and pasted the shortcut part of Json from another pre made face with shortcuts. I can see when adjust my shortcut placement the Json file adjusts to the new placements I make (x,y)
When pack I get two files 1 .bin file and one _packed.bin I've tried loading both on the watch it either goes to pre made face without my changes or the original amazfit that I over wrote the bin file in.
Any pointers please.
As I say not trying to copy others hard work would just like adapt my favourite face (Focused smoke v2 by nightwatch) as I have poor eyesight without my glasses and I can see the time etc without glasses.
