分页: 24 / 49
发表于 : 07 1月 2022, 14:16
发表于 : 10 2月 2024, 14:12
Zritwo
I found that Amazfit balance sunrise and sunset can't change image ,Did I make a mistake?
发表于 : 13 2月 2024, 20:22
toolsrme
@SashaCX75
Is there a way to stop the 'am' or 'pm' from being added to the display when using the "TT Hours : minutes" element of the "12 Digital time" widget? I can pick from 'am', 'Am', 'AM' it seams, but would like to remove it altogether and handle it on its own.
发表于 : 14 2月 2024, 04:42
1mylord
Thank you always.
Is there a way to make the desired image appear for a certain amount of time (about 10 seconds) by touching an area or button?
Please let me know if I need to add a script.
发表于 : 14 2月 2024, 17:18
@1mylord
You can try to use the button to start a timer and change the visibility of the image at the required intervals. To do this, you need to modify the watch face code.
You can try to use frame-by-frame animation in the editor.
发表于 : 15 2月 2024, 01:04
1mylord
SashaCX75, Thank you very much for your quick response.
发表于 : 16 2月 2024, 13:57
Powerade001
Hey SashaCX75,
Thank you for your Zepp app 'bluetooth notify'. I don't need to edit every watchface I download anymore to have the bluetooth disconnect notification.
Have a nice day!
Allan
发表于 : 20 2月 2024, 15:24
bjk8kds
Thank you very much..
发表于 : 25 2月 2024, 06:39
slimak131
Gtr4/Balance
After using any program, the double shortcuts on the watch face (short tap, long tap) stop working. This happens until you use any other operation on the watch.
Is there any solution?
edit
this error only occurs when exiting the application using a physical button. Exiting the application by touching the screen does not cause an error.
发表于 : 28 2月 2024, 00:13
wanders
@SashaCX75 , thanks for another great watchface tool.
I'm probably doing something wrong, but when I select "Random preview" or generate an animated .gif, I get random values that are clearly unconstrained, e.g.:
Since I want to use the .gif as a promotion on AmazfitWatchfaces, and since I'm generating this watchface in 11 languages, including Ukrainian, I'd like to have more-or-less valid random samples. What do I need to do to constrain the random values to valid timestamps? BTW, this is a 12-hour watchface, but I'll be doing 24-hour versions for the non-English versions.
发表于 : 28 2月 2024, 01:51
wanders 写了: 28 2月 2024, 00:13
Since there is no watch face to check, I would like to suggest and guess as follows.
You could try checking the file sorting of numbers that is used to display images of the viewing time. It looks like there might be an incorrect sorting error.
And in naming the file, I recommend the following:
if you use a name that consists of 1 digit. It is recommended to start at 0, such as Time0-Time9 or Time_0 - Time_9.
If you use 2 digits and start at 1, it is recommended that the number that follows has 2 digits, such as Time_01 - Time_10.
As far as I've ever created the preview.gif by random, I haven't encountered any of the above problems.
But if you check If everything is set correctly, you can try customizing the settings to create a Preview.gif by:
Edit ---> Data for preview --> Set your desired values in "Values1 - 12"
Then Save Preview Values to keep for future use.
Next time, if you want to make a preview as set, "load Value" before creating the preview.gif.
Hope it will be useful to you.
发表于 : 28 2月 2024, 15:41
wanders
@asoo , thanks, that looks like the ticket!
Duh, I had the hours digits aligned left, not right. That was my REAL problem.
Thanks, again @SashaCX75 and @asoo
发表于 : 28 2月 2024, 18:07
Random preview data has the same limitations as normal previews. These errors usually occur if there are problems with image sorting.
Random preview data is best used to check that individual elements are displayed correctly. I would not recommend using them for creating gif files.
When opening a project, the data is generated randomly if there are no saved preview settings. But in this mode the gif file will contain all days of the week and all months. This helps to notice possible errors. Otherwise, data generation by the button and when opening a project does not differ.
发表于 : 02 3月 2024, 13:29
Franckiam
Hello, I have an Amazfit Active for a short time, "Watch Face Editor" V10.3 allows you to make WatchFaces for this model, but after I found no way to be able to install it on my watch. Anyone have a solution?
edit: android 12 - zepp 8.5.3
发表于 : 02 3月 2024, 15:04
Franckiam 写了: 02 3月 2024, 13:29
Try reading this thread.
It involves installing watchface on Balance using QR Code, but this method can be used with Active and devices that use Zeppos as well.
It has been confirmed that this method can be used with Active.
viewtopic.php?p=17456#p17456
发表于 : 03 3月 2024, 07:42
dohanin
[deleted]
发表于 : 05 3月 2024, 17:58
wanders
I'm struggling to get the behavior I want out of hmUI.widget.IMG_LEVEL for PAI, and I'm trying to understand how the IMG_LEVEL widget works. I hope this subject is appropriate for @SashaCX75 's thread. If not, please let me know where to post.
The desired behavior: a PAI icon is displayed on the watchface. When a weekly PAI level is above 100 (the target or goal), another image is displayed (this is the IMG_LEVEL image).
What I don't understand is how many images need to be in the array (it seems like only one should be necessary) and how the code understands at what level to display the image in the array.
The relevant code from index.js (generated by the SashaCS75's tool) is:
代码: 全选
            normal_pai_icon_img = hmUI.createWidget(hmUI.widget.IMG, {
              x: 310,
              y: 220,
              src: 'pai_icon.png',
            normal_pai_image_progress_img_level = hmUI.createWidget(hmUI.widget.IMG_LEVEL, {
              x: 310,
              y: 220,
              image_array: ["pai_000.png","pai_001.png"],
              image_length: 2,
              type: hmUI.data_type.PAI_WEEKLY,
So, there is no level indicated here. I assume that the level sampled is totalpai, and that this is implicitly set by type: hmUI.data_type.PAI_WEEKLY. Even if this is the case, how is the index for the image array computed? I cannot find the documentation for this in the online documents for Zepp OS.
Eventually, once I get this working, I'll do similar IMG_LEVEL things with a PAI_DAILY widget.
Thanks in advance for any help.
发表于 : 05 3月 2024, 21:16
@wanders
The image display algorithm for the IMG_LEVEL widget has changed in different firmware. Previously it worked the way you do it. I don't know what the algorithm is now. I can advise you to try to use only 1 image.
发表于 : 09 3月 2024, 22:50
wanders
“If you want a thing done well, do it yourself.” - Napolean Bonaparte
I'm trying to follow Napolean's advice; I'm trying to get precise control of an IMG_LEVEL widget associated with steps. In the code below (inserted before widgets are constructed), I create a step sensor, an IMG_LEVEL widget with two images, set the level to 1, and I set up a callback routine when the step count changes. In the callback, if the step count is greater than the target, I set the level to 2.
代码: 全选
         // start user_script_start.js
        let normal_step_image_progress_img_level = ''
	const step = hmSensor.createSensor(hmSensor.id.STEP);
	normal_step_image_progress_img_level = hmUI.createWidget(hmUI.widget.IMG_LEVEL, {
		x: 14,
		y: 221,
		image_array: ["shoe_000.png","shoe_001.png"],
		image_length: 2,
		level: 1,
	step.addEventListener(hmSensor.event.CHANGE, function () {
		if ( step.current >= step.target ) {
			normal_step_image_progress_img_level.level = 2;
        // end user_script_start.js
However, nothing is happening. I can think of several possibilities:
a) The widget is out of scope in the callback (I'm not a JS expert, not even a novice)
b) I'm using IMG_LEVEL wrong (I'm used to zero-indexed arrays)
c) I'm setting up the sensor and/or callback incorrectly.
d) My code is located in the wrong place in the script.
I'm entirely new to JS, and I'll only use it for ZeppOS watchfaces. Any help / advice would be warmly welcomed.
发表于 : 09 3月 2024, 23:05
You are trying to change the widget properties incorrectly. You can read about how to change widget properties here
https://docs.zepp.com/docs/watchface/ap ... tProperty/
In your case it is better to use hmUI.widget.IMG widget. Depending on the conditions, change the image using the command
代码: 全选
widget_name.setProperty(hmUI.prop.SRC, 'img.png');
or hide the widget
代码: 全选
widget_name.setProperty(hmUI.prop.VISIBLE, false);
发表于 : 10 3月 2024, 20:07
wanders
Thanks, @SashaCX75, that did the trick. I'm wondering if the sensor callbacks have an impact on performance, as the step counter (numerals) seem to have indeterminate lags, but then they've always been a bit laggy.
By the way, do you know if the PAI sensor also has a callback / "event listener" capability with a CHANGE event trigger? All the other sensors seem to have this capability, but it doesn't seem to be documented in the ZeppOS pages, if it does exist.
发表于 : 12 3月 2024, 13:10
dohanin
Hello, I'm using GTS 4 Mini. I found that not all data on the AOD screen is updated immediately. Some are only updated after going back to normal mode. Is there a way to force these data update while staying in AOD? I guess probably it has something to do with sensors and event listeners. But I'm not a programmer, so would be glad if someone could give me a hint! Thanks.
发表于 : 24 3月 2024, 11:03
dohanin
Hello, is there a way to put music control directly as buttons on the watchface, say, the "Prev"/"Play"/"Next" buttons?
I can see from the Zepp OS documentation (https://docs.zepp.com/docs/1.0/watchfac ... rId/MUSIC/) that there are functions for these buttons, e.g. music.audPlay() , but I don't know how to put these in to the code session of the watch face editor.
发表于 : 24 3月 2024, 17:35
@dohanin
You can read about using the buttons here https://docs.zepp.com/docs/1.0/referenc ... et/BUTTON/
In the past you could only control music playback on the watch, not on the phone. I don't think that's changed.
发表于 : 24 3月 2024, 17:42
Version 10.4
Mirror
发表于 : 25 3月 2024, 09:18
dohanin
SashaCX75 写了: 24 3月 2024, 17:35
@dohanin
Thanks for your reply. As I'm using Gadgetbridge and Tasker on my phone, I am able to catch logcat entries for actions of pressing buttons on the watch's music app, but am still not able figure out how to send data directly by pressing a button on the watchface. I can see the watch would send data to the phone for activities such as changing the step target, removing a to-do list item, etc., but these are triggered by the other watch apps. If I can, for example, set the step target by pressing a button on the watchface, then it may be possible to catch such action on the phone, but I don't know how. If you have any idea how this can be done, please give me some hints, thanks!
