Сторінка 23 з 24
Додано: 17 грудня 2019, 17:06
Зображення
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Re: AmazFit WatchFace editor for Windows by SashaCX75
Додано: 23 січня 2022, 02:27
rooooi
Hello, hope someone still uses this!
I was able to make a Watchface from scratch using the program but once I try packing it nothing happens, a black window appears and shortly vanishes with no .bin in sight.
On the bottom right corner of the index thing it said 3.3MBs so I thought it was the size but even after lowering it to 1.75 the results were the same, black window and nothing.
Додано: 23 січня 2022, 08:44
Guydu91
rooooi писав: 23 січня 2022, 02:27
The maximum size is 1.5...
I think it's your problem. 😉
Додано: 23 січня 2022, 08:53
The maximum size depends on the watch model.
Exceeding the maximum size affects the operation of the watch face on the watch, but does not affect the created bin file. Look for errors in the log file.
Додано: 23 січня 2022, 17:13
FeRu
Check if the png files are numbered consecutively from 0000 to last . Even when only one is missing or when you have mistake with one file name, your WF file will not be created. Check the log file.
Додано: 23 січня 2022, 17:41
rooooi
I umm.. I don't think I have a log file...
I'm sorry i'm really really new to this.. I have the PNG's, the .JSON file and the preview states but no log... How do I get it?
I've also numbered the PNGs nicely and have no errors when loading the .JSON on the app. I've since lowered the size down to a nice 1.6MBs but nothing. Black window, and nothing..
Edit. I'm challenged... I made sure to note that every folder leading to the files but not the folder on which the files were actually on... thank you so much for all your help! I'll finally be able to move on to trying it on the watch!
Додано: 23 січня 2022, 17:57
rooooi
The log file should appear next to the .JSON file when the watch face is created.
Додано: 23 січня 2022, 21:23
FeRu
rooooi писав: 23 січня 2022, 17:41
(-‸ლ) 😆
I'm glad that you found a solution...I'm sure that every WF maker from this community made some simple, idiotic and funny mistake that took a lot of nerves :lol:
Додано: 24 січня 2022, 23:33
rooooi
I come to you with another ridiculous issue.. This time I have no issues with the files themselves.
It's the animations I'm having trouble with, I set an icon to move between the bottom of the screen up a tiny bit, looks fine in the app but doesn't work on the watch..
I have the animation speed set to 1000 and timer to 1, so it's not incredibly fast. It's also not the last PNG which I know is an issue
Додано: 25 січня 2022, 18:54
If I remember correctly, the animation time should be 0 or a multiple of the animation speed.
Animation speed is the duration of one animation cycle in milliseconds.
Додано: 25 січня 2022, 22:44
rooooi
I have finally made it work. I tinkered with a lot of different animation speed and animation time combinations and multiples but nothing worked, only after trying to use both animations at once (movement and frame animations) did I actually get it to work...
It happened last time I tried this too so maybe you need to export one with both for them to work? and then you take the one you don't want out? Definitely seems like it, i'll be doing another final watchface soon and will do the same thing to check if having both works right away
Додано: 09 лютого 2022, 01:11
YNOVAD
Tengo este problema al querer empaquetar y comprimir el bin para una esfera del trex
Зображення
Додано: 09 лютого 2022, 15:24
YNOVAD
It's hard to say without seeing the project. It seems that the "distance" parameter does not contain all the necessary parameters.
Додано: 09 лютого 2022, 15:42
YNOVAD
Thanks so much. You are so acerted. I fix the problem with a png dot for decimals. Thanks Genius!
Додано: 14 лютого 2022, 08:39
demieg
Hi All,
I'm very happy with this editor. Big thumbs upp for Sasha ;D
I have a problem with icons for the battery. I've designed 6 icons for the battery. When I test the icon in the editor it works fine. When I test in with my GTS watch the battery icon doesnt match the percentage. (the icon displays a lower percentage). Anyone knows how to fix this? Thanks in advance! 8-)
ps. I've included the compressed Bin-file.
Додано: 15 лютого 2022, 12:32
demieg
No way.
Huami recommends using 10 images to display the battery charge. The preview in the editor was checked for exactly 10 images. If you use fewer images then it will work, but it may not match what is displayed in the editor.
Додано: 16 лютого 2022, 20:28
demieg
SashaCX75 Thx, I'll try again with 10 images!
Додано: 02 квітня 2022, 06:43
tsvettydjs74
With this program can I change an already existing face for t-rex pro who is with .bin? And how does this happen?
Додано: 03 квітня 2022, 21:34
Guydu91
tsvettydjs74 писав: 02 квітня 2022, 06:43
To open and create watchfaces for T-Rex Pro you must use this editor:
viewtopic.php?f=29&t=1888
Read the whole post carefully. It's a bit long but very useful...
Best regards
Додано: 20 червня 2022, 07:48
demiurg1
Додано: 08 вересня 2022, 23:59
Giraz82
Hello to everyone!
I'm new to WF editing, so please be patient if my question is stupid.
I want to edit an existing WF, but when I download it, I just get a zip file, not a bin file.
I tried to add bin extension and to unpack with this tool, but it didn't work.
How should I proceed?
The WF is this one: https://amazfitwatchfaces.com/gtr/view/25903
Thank you in advance.
Додано: 09 вересня 2022, 00:22
Giraz82 писав: 08 вересня 2022, 23:59
Hello to everyone!
"AmazFit WatchFace editor for Windows by SashaCX75"
That you can't unpack because the tool you are using It's a GTR tool. It's not for GTR3
But that WF link you talk about is GTR3 watchface
Normally, the watchface of the GTR3,4 already has a zip extension.
If you want to unpack and edit GTR 3 you must to use this program
"Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3)"
!! Watchfaces of GTR , GTR2 , GTR3 have different format and cannot sync across models !!
So after unpacking, you can only use the unpack image to create a new watch face.
Додано: 12 вересня 2022, 20:25
Giraz82
Thank you so much!
Додано: 13 січня 2023, 12:27
ziramog777
Its valid for Trex2?
Додано: 13 січня 2023, 12:49
ziramog777 писав: 13 січня 2023, 12:27
Program for editor or create T-Rex 2 watchface , you can found in this link :
Додано: 12 лютого 2023, 11:33
HenriiTT
Amazfit Band 7?
