Pagina 21 di 24
Inviato: 17 dic 2019, 17:06
da SashaCX75
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Re: AmazFit WatchFace editor for Windows by SashaCX75
Inviato: 07 mar 2021, 02:06
da Fringo
SashaCX75 ha scritto: 05 mar 2021, 16:35
Rcappa ha scritto: 05 mar 2021, 02:44
Thanks but its there any way to login into site in English. I can't decode the Catcha in Russian
A little later, when the translation is corrected, I post the editor on this forum.
It works on ZEPP E Circle too! Thank you very much! I look forward to improved version :)
(I'd got resized images and coordinates from tool for GTR47, using converting function)
Inviato: 07 mar 2021, 08:46
da ajeto
I'm getting errors with main.py when decompiling
https://amazfitwatchfaces.com/gtr/view/12898
after decompressing
Codice: Seleziona tutto
raise IndexError(f"Parameter {parameterId} isn't supported for {currentType}")
IndexError: Parameter 2 isn't supported for <class 'watchFaceParser.elements.gtr2.basicElements.circleProgress.CircleProgress'>
Inviato: 07 mar 2021, 09:14
da asoo
ajeto ha scritto: 07 mar 2021, 08:46
after decompressing
viewtopic.php?p=8393#p8393
Inviato: 07 mar 2021, 10:41
da SashaCX75
Inviato: 09 mar 2021, 12:41
da rubiales41
hello, how much can the sphere weigh in megabytes, at most ?, for GTR 2?
Inviato: 09 mar 2021, 23:07
da mehrdadrahimian
SashaCX75 ha scritto: 07 mar 2021, 10:41
AmazFit WatchFace editor 2 with support for GTR 2, GTS 2[/color][/size]
Hi. Please also support the Bip u & Bip U Pro models. They are not supported in any of the Amazfit software. And it is not possible for them to be unpacked BIN file. Thank you for your efforts
Inviato: 11 mar 2021, 22:26
da lucaslee
whether there will be a Polish version for this application?
Inviato: 12 mar 2021, 19:16
da r33ck
Horatius80 ha scritto: 17 feb 2021, 13:57
fkicin ha scritto: 16 feb 2021, 21:04
It's my first post so Hi all.
Sasha what is the official (or other) soft to edit watchfaces for GTR2? i can see custom wf here but i can't find any tool to creat such custom image :(
Here is "tutorial" video how to obtain access to Huami official develop tool for watchface creation. It is only on-line tool
(I see a similar question but I haven't found an answer, please and thank-you)
Hi All,
Many thanks to dimas for the youtube video on Huami registration. I'm in process.
Question: How to download an internal watchface? To start I'd like to add DND and bluetooth icons to the Multifunction WF in Zepp but can only find it in Zepp. GTR2, Pixel 5 phone and it isn't in any folder I can access.
Rick
Inviato: 27 mar 2021, 11:13
da gengtrex
Your T-rex editor is so awesome.
Is watchface editor for T-rex Pro now available.
Thanks a lot in advance.
Inviato: 27 mar 2021, 18:41
da SashaCX75
gengtrex
My editor is not designed to work with T-Rex Pro watch faces. The site has one dial made for this model. Ask its author what tools he made it with.
Inviato: 28 mar 2021, 04:40
da gengtrex
SashaCX75 ha scritto: 27 mar 2021, 18:41
@gengtrex
I see. Anyway, thank you again for the editor and lots of advices. :)
Inviato: 03 apr 2021, 14:23
da yakface
Im also very interested in what application was used to create the TREX PRO watch faces and if there is a way to convert existing TREX watch faces to be TREX PRO compatible.
Inviato: 04 apr 2021, 18:16
da Horatius80
SashaCX75 in my humble opinion, the principle of watchfaces for T-REX PRO will be the same as for GTR2 (support for widgets etc.), only it will be necessary to adjust the resolution to 360x360.
So Your Watchface editor 2 will be applicable. Correct me if I'm wrong
Inviato: 05 apr 2021, 16:09
da SashaCX75
Horatius80 ha scritto: 04 apr 2021, 18:16
@SashaCX75 in my humble opinion, the principle of watchfaces for T-REX PRO will be the same as for GTR2 (support for widgets etc.), only it will be necessary to adjust the resolution to 360x360.
Yes, the principle is the same. Probably the next version of the editor will support T-REX PRO.
We need T-REX PRO owners ready to test this update.
Inviato: 07 apr 2021, 16:17
da spidercrab
SashaCX75 ha scritto: 05 apr 2021, 16:09
Excellent. I will certainly be testing. Standing by.
Inviato: 08 apr 2021, 14:47
da Thinkpad
I'm ready to test this update.
Inviato: 11 apr 2021, 11:50
da andijbellinger
I've just got a t-rex pro and would be happy to test.
Inviato: 18 apr 2021, 04:43
da Turtl3sh3ll
T Rex Pro User Here, ready to test & Learn watchface creation.
Is the executable hosted on a stable platform yet? Suurceforge / etc?
Inviato: 20 apr 2021, 14:11
da pory
Rady to test!
Inviato: 17 mag 2021, 07:30
da CASIONFAN2021
Thanks to sasha for this amazing product. I would ask that there be an update to the watch face editor 2 for the t rex pro that allows the entries for moon phase and the sunrise sunset that is present on the stock watch faces. Is that possible?
Inviato: 19 mag 2021, 11:24
da maortrol
CASIONFAN2021 ha scritto: 17 mag 2021, 07:30
Why don't you ask that in the WatchFace editor 2 thread?
viewtopic.php?f=29&t=1888
Inviato: 24 mag 2021, 05:00
da gengtrex
with the t-rex editor.
when i load .bin to notify app, it always shows 'unable to retrieve preview image'.
how can i fix this and make it show?
thanks in advance.
Inviato: 24 mag 2021, 14:48
da CASIONFAN2021
Not sure. I've had a few faces that show a preview and others that don't
Inviato: 24 mag 2021, 15:31
da SashaCX75
gengtrex
I didn't quite understand what kind of error occurs. Send a window with an error and describe in detail the actions in which the error occurs.
Inviato: 25 mag 2021, 02:34
da gengtrex
SashaCX75 ha scritto: 24 mag 2021, 15:31
@gengtrex
it shows as the pic below, after i choose the .bin in notify app. anyway the uploading is successful everytime.
