Page 3 of 3
Re: 欢迎大家交流、提交 zepp OS 相关经验、问题,可以得官方第一时间的回复。
Posted: 26 Feb 2022, 23:25
by Strausswu
息屏情况下发生偏移并且无法确定偏移方向。观感有所影响
Posted: 01 Mar 2022, 06:08
by paulkva
TXK wrote: 23 Feb 2022, 01:03
paulkva wrote: 01 Feb 2022, 02:25
官方回复,已经有新版本上线,请清除浏览器缓存再测试一下,这次问题应该解决了
The official reply is that a new version has been launched. Please clear the browser cache and test it again. This problem should be solved
很抱歉,它仍然不适合我。 表盘看起来与我上次尝试发布时的外观相同。 我已多次清除缓存并尝试隐身/私人浏览。
I'm sorry to say it's still not working for me. The watch face looks the same as it did the last time I tried and posted. I've cleared my cache multiple times and tried incognito / private browsing.
Posted: 01 Mar 2022, 06:35
by TXK
Strausswu wrote: 26 Feb 2022, 23:25
不定时偏移像素显示内容。这是为了解决烧屏问题。
Posted: 01 Mar 2022, 06:37
by TXK
paulkva wrote: 01 Mar 2022, 06:08
收到,我继续反馈。
OK, I'll continue to feed back.
Posted: 12 Mar 2022, 08:04
by yshpc123
我制作了gts2 mini的手表,但无法播放。 这个错误怎样才能解决? :?: :?:
I made a watch face for gts2 mini, but I couldn't export it. How can I solve this error? :?: :?:
Posted: 14 Mar 2022, 03:12
by TXK
yshpc123 wrote: 12 Mar 2022, 08:04
공식적으로 피드백을 하고 있으니 잠시만 기다려 주세요.만약 최신 진전이 있다면, 나는 짧은 소식과 여기에서 회답하는 두 가지 방식으로 당신에게 통지할 것입니다.
Feedback to the official is in progress. Please wait a moment. If there is any latest progress, I will inform you by short message and reply here.
正在向官方反馈,请稍等。如果有最新进展,我会用短消息和在这里回复两种方式来通知您。
Posted: 17 Mar 2022, 21:45
by TamazonX
Hi! I went to export a watch face and got the same error from above. Any info?
Posted: 27 Mar 2022, 16:13
by Antalnekrisztina
Hi. I also received the Export failed message. GTS2 Mini
Posted: 29 Mar 2022, 15:07
by TXK
Antalnekrisztina wrote: 27 Mar 2022, 16:13
Posted: 29 Mar 2022, 15:08
by TXK
TamazonX wrote: 17 Mar 2022, 21:45
Posted: 30 Mar 2022, 15:30
by TXK
yshpc123
TamazonX
Antalnekrisztina
This problem has been fixed online the day before yesterday. You can try to export it again. The feedback from the external developer group is a problem. If there is still an error, it should be that the volume of the dial file is too large after packaging. You can try to reduce the number of pictures and export it again
这个问题前天已修复上线了,可以尝试再导出试试,和外部开发者群里反馈的是一个问题,如果仍有报错,应该是表盘文件打包后体积过大,可以尝试减少下图片数量再导出试试
Posted: 03 Apr 2022, 22:44
by mimidudu
Yes, it did export again, but with the zab extension, what would this type of extension be?
Posted: 11 Apr 2022, 01:24
by TXK
mimidudu wrote: 03 Apr 2022, 22:44
ZAB 是ZIP格式, 使用解压缩软件解压它
Zab is a ZIP format. Use the UNZIP software to decompress it
Posted: 12 May 2022, 12:24
by aircychen
请教各位华米智能运动手表2用amazfaces 选择表盘通过Zepp安装表盘,为什么总是显示表盘数据拉取失败?无法安装第三方表盘
Posted: 16 May 2022, 00:50
by TXK
aircychen wrote: 12 May 2022, 12:24
1\ 你是不是下错了表盘型号的表盘.你的手表是什么样的?拍个照片,
2\你下载的表盘是那一个?提供一下链接
Posted: 16 May 2022, 02:16
by aircychen
Posted: 16 May 2022, 02:22
by aircychen
下载这里面的表盘文件
Posted: 16 May 2022, 05:02
by aircychen
型号AC1903
Posted: 16 May 2022, 15:06
by TXK
aircychen wrote: 16 May 2022, 02:22
下载这里面的表盘文件
1、你的手表是华米智能表1代,好像。发行量很少。
2、你下载的表盘是运动表系列(1代~3代)专用的。
3、还有,你拉取失败的截图背景上的手表样式,好像是智能表1代青春版(低配版)。
综上所述,你的手表,在本网站上,并没有支持的表盘。你只能使用官方的表盘。
Posted: 24 Jun 2022, 19:35
by fwz233
wing0826 wrote: 06 Dec 2021, 14:27
十分谢谢!
我不论在ZEPP内反应或是官网找半天、发MAIL 甚至在WECHAT客服问半天都没结论也没人回😅
GT2目前也都还是很赞 很喜欢GTR2不锈钢版 可惜GTR3 PRO没有不锈钢或钛版
我也期待不锈钢版本 :D :D
