Page 17 of 49
Posted: 07 Jan 2022, 14:16
by SashaCX75
Posted: 25 Apr 2023, 00:01
by Hviegas
So just to make easy for everybody.
After creating your watch face, you need to open the file index.js and then add a code.
Please add the variables with others variables.
if you have any doubt, just download my watch face and open the code.
edit the 'x', 'y', 'w', and 'h' to fit in your watch
let btnbrightnessdown = ''
let btnbrightnessup = ''
btnbrightnessdown = hmUI.createWidget(hmUI.widget.BUTTON, {
          x: 0,
          y: 130,
          w: 97,
          h: 72,
          text: '',
          normal_src: '0_Empty.png',
          press_src: '0_Empty.png',
          click_func: () => {
            const currentBrightness = hmSetting.getBrightness();
            if (currentBrightness >= 10) {
              hmSetting.setBrightness(currentBrightness - 10);
          show_level: hmUI.show_level.ONLY_NORMAL
        btnbrightnessdown.setProperty(hmUI.prop.VISIBLE, true);
        btnbrightnessup = hmUI.createWidget(hmUI.widget.BUTTON, {
          x: 97,
          y: 130,
          w: 97,
          h: 72,
          text: '',
          click_func: () => {
            if (currentBrightness <= 90) {
              hmSetting.setBrightness(currentBrightness + 10);
        btnbrightnessup.setProperty(hmUI.prop.VISIBLE, true);
Posted: 25 Apr 2023, 18:17
by SashaCX75
Lukimator wrote: 24 Apr 2023, 21:06
Is that correct? I have 2 or 3 watch faces displaying altitude installed on my T-Rex 2. I don't know how they made those though
If you have seen such watch faces, why not unpack them and see how they are made.
Here is an example of the Altitude display.
hmUI.createWidget(hmUI.widget.TEXT_IMG, {
    x: 240,
    y: 240,
    font_array: ["num_0.png","num_1.png","num_2.png","num_3.png","num_4.png","num_5.png","num_6.png","num_7.png","num_8.png","num_9.png"],
    padding: false,
    h_space: 0,
    angle: 0,
    align_h: hmUI.align.LEFT,
    type: hmUI.data_type.ALTITUDE,
Posted: 25 Apr 2023, 18:24
by SashaCX75
Version 7.3
Mirror
Posted: 26 Apr 2023, 09:35
by Lukimator
SashaCX75 wrote: 25 Apr 2023, 18:17
    x: 240,
    y: 240,
    padding: false,
    h_space: 0,
    angle: 0,
Because they are from the official watch face store and I have no idea how to get them so I can unpack them. I read somewhere that now you need root to be able to see the folder were they get stored
Posted: 26 Apr 2023, 13:09
by ZduneX25
@Lukimator all available data_type's: https://github.com/tytydraco/zepp-dump- ... r4.js#L682
Posted: 26 Apr 2023, 16:00
by Lukimator
ZduneX25 wrote: 26 Apr 2023, 13:09
So the altimeter is there, I guess it can only be coded in because the UIs don't give the option
Posted: 28 Apr 2023, 13:24
by ZduneX25
@Lukimator so I am creating a dial that supports altimeter and I can tell you to use hmUI.data_type.ALTITUDE for os 1.0 and both hmUI.data_type.ALTITUDE/ALTIMETER return the same value on os 2.0
Posted: 28 Apr 2023, 19:06
by Lukimator
@ZduneX25 yep, I managed to edit the index.js and created the value manually from there using the altitude data point
Posted: 01 May 2023, 13:51
by Ferrari70m
I intend to buy a GTR4 (limited edition). A selling point, however, is that I can design my own watchfaces, as I have already done with my GTR2 (which is unfortunately defective after a year with a bootloop). Is it possible to create wf with GTR3 watchface editor an bring them onto a GTR4? Or is there another watchfaceeditor?
Posted: 08 May 2023, 00:13
by rush2112
@SashaCX75
Can you tell me what is the reason when I do install a face watch on my GTR3 Pro 480x480 Size with the tools 7.3 Amazfit , when the watch goes to sleep after a do turn my wrist for wake up the watch the face watch inside the display on the screen starting moving up and down a bit ....Please reply ..thanks
Posted: 08 May 2023, 01:40
by asoo
rush2112 wrote: 08 May 2023, 00:13
It shouldn't be a problem caused by program editor
It's probably caused by the screen saver function of firmware on the watch.
According to my attached link, I'm not sure in this link is your question you asked and that have receive the answered.
viewtopic.php?p=15279#p15279
Posted: 09 May 2023, 05:24
by Kakoman532
hola, al intentar abrir el ejecutable se queda intentando entrar y se cierra al momento sin llegar a mostrarme nada mas. tengo windows 10 de 64 bits, nose cual puede ser el problema. necesito ayuda gracias
Posted: 09 May 2023, 11:42
by Kakoman532
hello, when trying to open the executable it keeps trying to enter and closes at the moment without showing me anything else. I have windows 10 64 bits, I don't know what the problem could be. I need help thanks
Posted: 09 May 2023, 16:36
by stevecovieo
Is there a reason why the editor wont open/display certain watchfaces? They are from here. I cant get any GTR4 faces to unpack correctly. All t shows s a black circle and under editng only shows background. no other info.
Posted: 09 May 2023, 18:04
by asoo
stevecovieo wrote: 09 May 2023, 16:36
If watchface have add custom script , which those scripts are not the standard of the program editor
The program will not be able to unpack that watch face properly.
The program can only unpack images.
Posted: 10 May 2023, 06:04
by jakubgaluszka
May i ask? Will there be an update for the app so i can convert other model wf to GTR mini? thanks
Posted: 10 May 2023, 16:42
by SashaCX75
@jakubgaluszka
In the next version of the editor, I plan to add support for the GTR Mini and T-Rex Ultra models. The T-Rex Ultra watch has not been tested yet.
Posted: 10 May 2023, 17:04
by mirda69
@SashaCX75
First of all, you are doing a great job and I thank you on behalf of myself and everyone else who uses your editor
Now I have one question:
- there is an option to add units for km and miles.....can you do the same for celsius and fahrenheit?
It would be very helpful as there are many who use units in the imperial system
Thank you in advance...
Posted: 11 May 2023, 08:37
by jakubgaluszka
SashaCX75 wrote: 10 May 2023, 16:42
@jakubgaluszka
Thank you!
Posted: 12 May 2023, 07:32
by ktomcat
Thank you for this great editor app. I'd like to ask, is it possible to set background image according to time? I mean in the night its a night themed, morning/sunset, and day themed. Or is it possible to connect it to the sunset/sunrise time? I'd like to set 3 background images in a way like if its possible
Posted: 12 May 2023, 16:45
by SashaCX75
@mirda69
The ability to automatically change the image for degrees celsius and fahrenheit is in the plans for future versions. But it is only possible to define the units correctly on ZeppOS 2.0? On models with ZeppOS 1.0 there is no such option, you can only try to determine based on the region.
Posted: 12 May 2023, 16:51
by SashaCX75
@ktomcat
In the editor, you can only set the image for sunrise and sunset. This image can be used to cover the background during the day.
If you want something more complex, you need to write code, monitor the current time and change the background image depending on the result.
Posted: 28 May 2023, 23:58
by taw_bip
I must be missing something. I haven't made a watchface for a while and I wanted to edit an existing one.
I've tried to open the following file:
https://amazfitwatchfaces.com/t-rex/view/12183
but I've had no luck getting the .bin file to unpack. Any ideas?
Posted: 29 May 2023, 01:57
by asoo
taw_bip wrote: 28 May 2023, 23:58
The watch face you want to edit The owner has created it using an encrypted script and custom script. So this program editor cannot be opened it. If you want to edit It is advisable to contact the owner of the work.
Posted: 29 May 2023, 02:05
by taw_bip
Thank you. It's a bit sad. I didn't care if people reworked my watch faces, not that they were anything spectacular. But it certainly doesn't help those of us who are just trying to learn.
