Page 2 of 5
How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Posted: 05 Aug 2019, 19:49
by GIK-Team
Detailed instructions for installing custom watch faces on Amazfit GTR, GTS, T-Rex, Verge Lite, Amazfit Bip smartwatches, and Cor and Mi Band 4 smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp (Amazfit)
For a successful installation, you need to connect your gadget to a smartphone on Android or IOS with the Amazfit (Zepp) app installed. You also need to have installed file manager and pre-download the watch face that you would like to set on your watch.
Installation for Android
- First, you need to install one of the stock watch faces available in Zepp (Amazfit)/Mifit (if you have already installed one, you may skip this step).
- Open the folder with the downloaded watch face in the file manager with the path:
- Zepp (Amazfit) /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
- Mi Fit /Android/data/com.xiaomi.hm.health/files/watch_skin_local/
- Go to any of these folders and find the .bin file. Copy the .bin file name.
- Name example for bin: 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
- Name example for zip: UQkNrGEQmaPvYbLmGseWkOkUCHDDkOBf.zip
- Go to the custom watch face and rename it using the name of the standard watch face.
- Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
- Open the Zepp (Amazfit)/Mifit app and install the stock watch face, which file you replaced.
Android apps
AmazFaces app
Gadgetbridge (Android)
Notify & Fitness for Amazfit (Android)
Amazfit Replacer (Android)
Installation for iOS
You may also use
our application or other, such as
AmazTools (iOS), to install watch faces
This manual is current at the time of writing.
If you notice any inaccuracies or mistakes, please, let us know.
Re: How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Posted: 25 Mar 2021, 12:52
by Bart1981
JC007 wrote: 18 Jan 2021, 03:04
Hello
Inside Android 11 you don't have access to the / Android / data / folder
How you do that ?
On my OnePlus 7T Pro with Android 11 I actually still do have that folder and therefore can upload watchfaces in the old way... Unfortunately the app doesn't seem to support it when it detects Android 11.
There is no gear icon next to the download button anymore. And sending the watchface using the app is way too slow. So now I use the 'pc method' again. GIK-Team can you please enable the file-transfer-method like on Android 10 but for Android 11. Because some people like me do still have acces the / Android / data / folder. This method is way faster compared to the wireless transfer method.
Posted: 28 Mar 2021, 19:45
by Pj27305222
But the Android Zepp app doesn't change the ICON, so If I have a couple of faces switched out, I can't see or remember which ones I've swiched and therefore it's quite useless.
Posted: 30 Mar 2021, 22:52
by John72
Hello I also have a problem via AmazFaces I can't install when I have mifit via IOS it doesn't work
iOS Tutorial: Installing AmazFaces watch face on Amazfit watches.
Posted: 01 Apr 2021, 20:53
by mrlawrencelam
iOS Tutorial:
https://www.youtube.com/watch?v=atPVnh4FS-c
Posted: 06 Apr 2021, 00:24
by usphisics
I just bought a T-Rex PRO and I also have Android 11.
Watching the video;
https://youtu.be/SCTHlbWZOIM
I noticed that the process/steps from the video doesn't apply to me
Not sure if it is because I have a PRO or because I have an Android 11 or even both at the same time...
Posted: 06 Apr 2021, 17:59
by Bart1981
usphisics wrote: 06 Apr 2021, 00:24
Watching the video;
It's the same for me. There is no way to select the option to replace the original watchface. The option just isn't there....
Edit:
After the update the old method is back again (2: fast) but still, the app doesn't see the installed original watchface and therefore can't use option 2. Also after the update the amazfitwatchfaces app doesn't seem to be able to discover the watch anymore. The synchronization within the Zepp app works without any issues
Edit 2:
After updating the app today the watch can be discovered again but it won't transfer the watchfaces to my gtr. Neither the slow (1) or the fast (2) methods work.
Posted: 23 Apr 2021, 13:13
by Fercka
Hi Friends, after I upgrade my phone to android 11, the app can not replace original faces from Zepp app.
The folder where use to be the the original faces in Zepp app in empty, nothing at all on it.
So, amazfitwatchfaces app can not find original faces to replace.
I didn´t find yet the new location where Zepp app is downloding the original faces.
Any solution for this issue???
regards
Posted: 07 May 2021, 11:33
by shantz
I am unable to replace the face in Amazfit Bip Lite, Android 11. Tried putting bin file in watch_skin_local folder but I dont see that in the app.
Posted: 08 May 2021, 09:33
by asadulhuq
Seems that this method cannot install a custom WF at least to Amazfit BIP. May be Amazfit has changed their protocol. Now you have to submit 3 files in to Mi Fit local skin folder. BIN, GIF (optional) and infos.xml files. The XML file is required to show up the WF on MiFit. I have made a step by step procedure to install BIP watch faces on Mi Fit. If you are interested you may have a look at the link shown below.
http://asadul.firstcloudit.com/how_things_work.htm
Posted: 16 May 2021, 15:30
by SKP
I was able to make the 1st set of isntructions work on t-rex pro by disabling wifi and mobile data before going to the zepp app to sync the watch face.
Posted: 17 May 2021, 12:50
by Fercka
It's because of restrictions imposed in Android 11. Apps are permitted to see only their own folders and not of those of other apps.
So, DATA folder looks like empty, but is not empty.
You can install "Files" app from Play store, it´s free, and you can browse into DATA folder and see all files on it, anyway doesn´t fix amazfitwatchfaces problem, but you can replace bin files manually.
Posted: 18 May 2021, 09:07
by pory
Hi when i install wach face whit amaztool and reboot my watch (t rex pro) the watch face disappear.
Any Solutions?
Ty
Posted: 19 May 2021, 05:48
by Darkitect
I used the GTS Watch Face Editor v10.0 by SashaCX75 and successfully created a bin file (I did get a warning that the file was over 1.5mb, I suspect because of the large unnecessary gif previews?). I followed the Android instructions and was met with "Couldn't sync, try again"
Has something recently changed? Should I be using a different compiler?
Posted: 27 May 2021, 19:26
by OsKaRn
GIK-Team wrote: 05 Jan 2021, 10:45
tyrfing15 wrote: 05 Jan 2021, 02:56
Does not work for BIP U PRO
Of course, they don't even have custom watchfaces yet.
Amazfit bip U faces works for me...
method is similar: you have to sync
a new face from the store in the Zepp app, but when it asks you to replace an old one abort the operation...
next, proceed to /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
69 on your device and locate the new folder, replace its contents with the custom face as told in the main thread, return to the Zepp app and finalize the syncing...
Posted: 11 Jun 2021, 00:33
by sheevack
Will anyone know when it will be able to do this in Android 11? I can't change for any of the ones in the catalog
Posted: 18 Jun 2021, 12:47
by carolavendano
Hi! Can someone help me to install watchfaces for mi band 6, iOS? Didn't find any topic about it.. ;(
Already have the Amazfit (it doesnt show mi band 6 option - only until 5) and Mi Fit apps, download some watchfaces - but it when I tryed to install one app doesnt connect to each other.
Posted: 20 Jun 2021, 22:04
by neonoafs
So theres no way to install on Android 11? Do I have to keep those ugly stock watchfaces? *sigh*
Posted: 04 Jul 2021, 14:12
by ajayt49
please help
Posted: 04 Jul 2021, 17:18
by Drongo
Describe your problem in more details.
Posted: 05 Jul 2021, 11:21
by Woofer38
As of today, I noticed that it is no longer possible to install watchface using this method. The same goes from the T-Rex-rex WF Android app. Amafit t-rex.
Posted: 20 Jul 2021, 19:55
by pochongote
GTR 2e + iPhone no he podido, ni intercambiar archivos, ni con zepp ni con mi fit... help pleace
Posted: 20 Jul 2021, 20:21
by pochongote
pochongote wrote: 20 Jul 2021, 19:55
lo logre instalando de por medio amaztools !!! funciona
Posted: 08 Sep 2021, 22:44
by dilguis
brockdisciple wrote: 09 Jan 2021, 14:49
FOR IPHONE WITH ZEPP:
I couldn't connect to my GTR from the AmazFaces app. So I did this and it worked
Download AmazTools
Download your watch face from AmazFaces
Click on the box with the arrow to send the file
Choose Amaztools
Then install the file
EASY
Thanks! Worked like a charm here too!
Posted: 18 Nov 2021, 15:00
by knorde
I have the zepp app, don't see the pad in the file manager.
Is this working in the zepp app and is the GTR 2(e) supported by this?
Posted: 18 Nov 2021, 17:22
by GIK-Team
knorde wrote: 18 Nov 2021, 15:00
