分页: 10 / 10
AmazFaces for iOS [Support]
发表于 : 17 11月 2020, 10:05
In this topic, you may report a problem with our AmazFaces app for iOS.
App version (Stable or Beta)
Watch model
Phone model
OS version
Description of your problem
Filling example:
代码: 全选
App version: 3.0.111 Stable
Watch model: GTR
Phone model: iPhone 11
OS version: iOS 14.2
Re: AmazFaces for iOS [Support]
发表于 : 20 12月 2025, 10:29
Stas
Happy to hear you figured it out! No worries at all, it’s an easy mistake to make with watch face compatibility. If you have any more questions or need help finding compatible alternatives for the T-Rex 3, just message us anytime.
paulbriant 写了: 20 12月 2025, 09:28
So I think this has come about due to me trying to use watch faces that aren’t supported for my T-Rex 3, (my bad) I tried some from the original T-Rex, the GTR 47mm and the GTR 2, so the error in this process has been me, I saw some Bell & Ross watch faces that I wanted and couldn’t install them now not knowing they weren’t compatible, so thanks for the information.
发表于 : 10 1月 2026, 08:55
Stas
Glad you resolved the issue. Feel free to reach out if you have any questions.
发表于 : 10 1月 2026, 14:31
Stas
Good to hear it’s sorted out. Let me know if you need any help.
发表于 : 22 1月 2026, 11:21
kamab
App version: 4.7.408
Watch model: mi band 9
Phone model: iPhone 13 Pro
OS version: iOS 26.2
In the selection of device, I cannot see Xiaomi Mi Band 9, maximum is 6
发表于 : 22 1月 2026, 22:09
Stas
Unfortunately, Xiaomi Mi Band 9 is not supported by our app at the moment, which is why it does not appear in the device list (the latest supported model is Mi Band 6). Support for new models may be added in future updates.
kamab 写了: 22 1月 2026, 11:21
发表于 : 07 3月 2026, 11:43
hakanerturk
App version: 4.8.422 Stable
Watch model: Xiaomi Smart Band 10
Phone model: iPhone SE (2020)
OS version: iOS 26.3.1
Hi, I'm putting a lot of effort into testing my newly created themes because I can't find Smart Band 10 support in the app. When will Band 10 support be available?
Or is there a platform I can try online?
发表于 : 22 3月 2026, 18:20
hakanerturk 写了: 07 3月 2026, 11:43
I'm actually in the same situation.Any luck?
发表于 : 15 6月 2026, 07:17
Lattenknaller
App version: 4.8.432
Watch model: Amazfit Balance and BIP 5
Phone model: iPhone 14 Pro MAX
OS version: IOS 26.5
Unfortunately, with the app version mentioned above, I can't install WF via Bluetooth, this worked fine with previous versions.
I've also been having an issue for the past few versions where I keep getting logged out. That used to work fine, too.
So I'd like to stay logged in and install my work via BLE.
发表于 : 15 6月 2026, 16:29
Lattenknaller 写了: 15 6月 2026, 07:17
Could you please try the latest beta version of the app and let us know if the issue persists?
You can download it here:
https://amazfitwatchfaces.com/external/35
We’ve made several changes related to Bluetooth communication and authentication, so it would be very helpful to know whether BLE installation and the login issue are resolved in the beta version.
发表于 : 15 6月 2026, 18:00
Lattenknaller
Even with the BETA version, nothing has changed. I can't download via BLE, and I have to log in every time I launch the app.
App Version: 4.8.433
发表于 : 18 6月 2026, 16:34
Lattenknaller
4.8.434 BLE install is now working 👍🏻
After restart the App I have to login every time 👎🏻
发表于 : 28 8月 2026, 14:36
gedas07
I have iPhone 16 and amazfit bip 6 , the version of aplicación is 4.8.436 , and when I intented to install any caratules never see the anouncement an never download the caratule . How can I do
发表于 : 28 8月 2026, 16:45
Stas
Could you please send us a few screenshots or, ideally, a short screen recording showing what happens when you try to install a watch face?
Also, please let us know how you are trying to install the watch face via Bluetooth or using a QR code.
gedas07 写了: 28 8月 2026, 14:36
发表于 : 29 8月 2026, 15:15
gedas07
Stas 写了: 28 8月 2026, 16:45
Yes, of course, it installs via Bluetooth, but the file never gets downloaded in the application.
https://streamable.com/k0qp97
发表于 : 29 8月 2026, 19:12
Stas
Thank you for the clarification.
We can see that the issue is related to the advertisement not loading. When the ad is blocked, the watch face file download cannot start.
Please temporarily disable any ad blocker, DNS filtering/blocking service, or similar privacy filter on your device/network, then restart the app and try downloading the watch face again.
We also recommend using the QR code installation method, as it is usually more reliable.
If the issue continues after disabling the blocker, please let us know and we’ll be happy to help further.
gedas07 写了: 29 8月 2026, 15:15
发表于 : 29 8月 2026, 23:09
gedas07
Okay, but on iOS it can't be installed via QR code, or at least I'm not sure it can.
I've tried with the 5G network and I think without any DNS ad blocker, and I've also tried with different iPhones and different iOS versions (18, 26, and 27), and it doesn't work on any of them.
发表于 : 30 8月 2026, 08:11
gedas07 写了: 29 8月 2026, 23:09
Yes, it works on iOS without any problems.
You can enable Developer Mode in the Zepp app on iPhone in the same way. After that, use the QR scanner built into Zepp to scan or open the watch face QR code and install it.
So QR installation is supported on iOS as well.
发表于 : 30 8月 2026, 08:26
Stas
Thanks for the details. Could you please check one more thing: do ads show normally for you in other apps or websites on these iPhones, or are ads blocked everywhere?
发表于 : 30 8月 2026, 13:38
gedas07
Wow, I didn't know QR code mode worked on iOS. I've enabled it and it works perfectly.
Regarding ad blockers, I have them installed, but even after disabling them all, an app called Wosti still shows ads. However, on Amazon Faces, I can't watch videos or download any cover art.
发表于 : 30 8月 2026, 17:34
Stas
Great to hear that QR code mode is working perfectly for you!
Ads help us keep the app free, although we completely understand they can sometimes be annoying. There is also a subscription option that removes all ads.
Alternatively, you can temporarily disable your ad blocker only when downloading new watch faces. Once the files are downloaded, installing them again does not require watching ads.
gedas07 写了: 30 8月 2026, 13:38
发表于 : 01 9月 2026, 08:16
gedas07
Thanks for all your help. Even though I've disabled ad blockers, I can't download watch faces in the app. And a second question: how do I view QR codes in the iOS app? The ones I've tried and that have worked were from the website.
发表于 : 01 9月 2026, 17:04
gedas07 写了: 昨天, 08:16
Could you please try the AmazFaces Lite version and let us know if the download issue still occurs?
https://apps.apple.com/app/amazfaces-lite/id6794642422
Regarding QR codes: they should also work on iOS. Once Developer Mode is enabled in the Zepp app, you can scan/open the QR code using the built-in scanner in Zepp.
If the Lite version works while the main app doesn't, that information will help us narrow down the cause of the problem.
发表于 : 01 9月 2026, 17:26
gedas07
Yes, the QR codes work, but I don't know how to view them in the app; it only shows me the option to download the watch face.
发表于 : 01 9月 2026, 17:45
gedas07 写了: 昨天, 17:26
The QR code is actually always the same for your account. Each user has their own personal QR code.
Here's how it works:
  • You choose a watch face in the app and tap Install.
  • The app uploads that watch face to your personal folder on our server.
  • Your personal QR code always points to that folder.
So every time you install a different watch face, the file in your personal folder is simply replaced, but the QR code itself never changes.
That's why you don't need to view a different QR code for every watch face. The same QR code will always install whichever watch face you selected most recently in the app.
Please note: this is how it works in the app only. On the website, it's different—each watch face has its own unique QR code, so every watch face has a different installation QR.
