分页: 1 / 24
发表于 : 17 12月 2019, 17:06
Version 10.0
Updated translation.
v 9.0
v 8.5
Fixed work with Verge Lite
v 8.4
Fixed Italian translation.
Added Chinese manual.
v 8.3
Bugs fixed.
Added a manual in English.
v 8.2
v 8.1
v 8.0
Italian language added.
Minor fixes.
Added animation support
Verge Lite Support Added
v 6.1
Added support for T-Rex.
Added support for shortcuts.
v 5.2
Updated bin file packer.
Added display of the year.
English support added.
Donate to the author
PayPal: [email protected].
Re: GTR_WatchFace editor for Windows by SashaCX75
发表于 : 22 12月 2019, 15:30
jeffrey38
发表于 : 29 12月 2019, 09:03
lukbe
Here is version 5.1:
https://mega.nz/#!rEpxRYiJ!Cv7AAYr4rFvS ... taBUYuYGQs
News:
- English language is supported
-support for compressed bin file
发表于 : 29 12月 2019, 13:00
gizmo2k4
hi, i made a WF for me , but how i make the bin file ? can anyone help me ? when i click on pack bin it doesn´t do anything .
发表于 : 29 12月 2019, 15:49
Louis_Cypher
lukbe 写了: 29 12月 2019, 09:03
News:
Just now that I was almost a Russian speaker?! Lol
+1 for instructions to compile .bin file.
发表于 : 29 12月 2019, 17:03
gizmo2k4
So how compile the bin file? Thx
发表于 : 30 12月 2019, 21:47
Lordalpine
In Version: 5.1 // How to set Language to English
Go to Hactponkn [ Option ]
Language Selection is there
The app will restart^^ Magic^^ 90% of the App is translated
发表于 : 30 12月 2019, 22:31
gizmo2k4
发表于 : 31 12月 2019, 13:36
calom
I cant put to work this tool... when I try to open a bin file just open a DOS window but close and nothing appear.
This tool can open an existent bin file face and then edit?
Any help please?
发表于 : 01 1月 2020, 19:23
Volker Liebzeit
jeffrey38 写了: 22 12月 2019, 15:30
Can you please tell me where to find it? Still can't unpack anything with weather.
发表于 : 02 1月 2020, 10:34
Lordalpine
Volker Liebzeit 写了: 01 1月 2020, 19:23
The way to avoid Unpack Problem is to retrieve "Fix array Branches"
With Loly Dev GTR, you can Unpack Bin with Weather... but when you will want to Unpack Bin with Weather and Extra Analogic Hand, You will have the same problem
I Had this problem, let me explain, I can Pack and unpack with the Python tool I had : All bin + weather.
Then I wanted to Unpack An Hikashi Watchface with Extra Analogic Hand [ Because I wanted to Know How it was done reading the Json file ] and I Can't Unpack It. The Tools says "Done" but I had only a log File with "an error of function not supported"
So I move to dpeddi Branch " Fix Array" To Pack and Unpack : Bin / Json + Weather + Extra Analogic Hand
Setup Python Tool environment
viewtopic.php?f=38&t=1110
SashaCX75 Gui Tool No Python Version
发表于 : 06 1月 2020, 11:49
Horatius80
发表于 : 07 1月 2020, 02:54
(607.67 KiB) 已下载 2156 次
发表于 : 08 1月 2020, 10:11
Lordalpine
asoo 写了: 07 1月 2020, 02:54
发表于 : 08 1月 2020, 10:33
Lordalpine 写了: 08 1月 2020, 10:11
( Thank SashaCX75 )
发表于 : 10 1月 2020, 17:52
Ekohero
have the problem with
I cant extract the bin.
发表于 : 12 1月 2020, 16:48
Matth78
Does compile work? I failed to do it with Windows without python. I don't understand what is wrong since it seems so simple! 😓
Edit :
For those who may have the same problem, mine was coming from no transparency on some image.
After adding transparency I have been able to pack. (But produced bin does not work on my watch T_T)
发表于 : 12 1月 2020, 22:12
Ekohero
no compile:
bin to -> open file directory does not work
so I cant edit this watchfaces
I wanted to see how the circles for calories and temperatur are done
发表于 : 13 1月 2020, 18:22
Version 5.2 full
The program is available for download now.
http://4pda.ru/forum/index.php?showtopi ... ry92847810
Обновил Графический редактор циферблатов
Добавлена поддержка набора иконок (иконки и набор координаты к ним) для прогресса шагов и батареи.
Добавлена возможность обрезки предпросмотра по форме экрана.
Исправлены ошибки в английской версии.
Google translate
Updated Graphical Dial Editor
Thank SashaCX75
发表于 : 14 1月 2020, 08:17
kampanita
asoo 写了: 13 1月 2020, 18:22
Version 5.2 full
Google translate
Thank SashaCX75
I can not download from 4pda.ru , not registered at that site....I tried to but don't understand russian and google translate didn't help also.
Could you upload 5.2 version to somewhere else ( mega / drive ... ) ?
发表于 : 14 1月 2020, 08:39
kampanita 写了: 14 1月 2020, 08:17
I'm not sure if 4pda allows copying this file for distribution outside of the 4pda in public.
To conclude, I sent my link that I uploaded for you in PM.
Please SEE your Private message
发表于 : 14 1月 2020, 10:44
Horatius80
[mention]asoo[/mention] please, if it is possibble, share the link with me also ... many many thx
发表于 : 14 1月 2020, 12:04
Horatius80 写了: 14 1月 2020, 10:44
@asoo please, if it is possibble, share the link with me also ... many many thx
Next time, who wants my link?
Please PM to me
Do not post request
Thank
发表于 : 19 1月 2020, 09:54
If you want to improve the translation or add a translation into other languages, write in PM.
发表于 : 21 1月 2020, 07:44
Kastelic
many many thx
发表于 : 21 1月 2020, 13:40
Starlince
hola a todos, perdón por mi petición, pero es que me he bajado el programa watchfaces tools en inglés pero no se como funciona, se que es mucho pedir, pero alguien me podría decir, indicar o remitir a unas instrucciones para un novato?? Muchas gracias de antemano y perdón por las molestias.
